Humpday Triviola
Last week I was asking about Incense Cedar. What is the industry term for what you get when you cut that wood into the size of 2 5/8"X 2 5/8"X 8"?
Tom
Humpday Triviola
Tom
Re: Humpday Triviola
I'm drawing a blank here.
I think I need a pencil to figure this one out.
Lee
Re: WAG
Billet?
Coming to the point...Answer
John was in first and Lee was correct as well. The actual term is "Pencil Stock"....self explanatory I'd say.
Tom
I must be thick
But that seems mighty thick for a pencil, so count me as one to whom "pencil stock" is not self-explanatory. Care to explain?
To make a pencil
Having spent some time in a pencil factory:
Pre-sized blanks are slit with a gang-saw into slabs 1/2 as thick as the diameter of a finished pencil.
A 2-sided molding machine grooves one side for the lead, and the other side for half of the traditional hexagonal profile.
2 profiled slabs are glued around the extruded graphite 'leads'. Then the glued up slabs are slit into pencils.
Re: To make a pencil
Okay. that makes sense as a process. I just don't see anything magical about that size. Probably just that the "acme pencil making machine company" captured the market, and the design has never changed.
Alex, you are probably right. By practice became a standard. No other magical reason for it.
T.
