Friday puzzle -- A dicey one, part 2
Last week's probability puzzle went over like a lead balloon, but I'll still post part 2 just in case anyone is interested.
Last week, we saw that if you roll one die, then roll two more in an attempt to get two that add or multiply to the first roll, that of the 216 ways of rolling those three dice, in 15 cases, the second and third die add to the first, in 14 cases, they multiply to the first, and in 188 they do neither. (In one case, 4-2-2, they both add and multiply)
Someone approaches you and wants to bet on a game where you throw three dice, and if one of them can be expressed as the sum of the other two, you pay him $1, while if one of them can be expressed as a product of the other two, he will pay you $1.50. No money changes hands if neither or both is possible.
Should you take this bet? Why or why not?
Re: Friday puzzle -- A dicey one, part 2
If I was a bettin' man
Sory I missed out on last week's puzzle.
Just looking at the combinatorics, your chance of a winning combination are 'unlucky' in a couple of ways. But you need to consider all the terms of the bet to calculate the expected payout.
Re: If I was a bettin' man
Go ahead and post it. I think we are all alone on this one, too.
Steven Antonucci
Gut feel is yes.
I assume that I understand the problem correctly, and even though he has a higher probability of being a winner, it's not enough to cover th 50% premium on the bet.
S
As before, there are 216 possible combinations of 3 dice. 13 of those are winning combinations and 14 are losers.
Despite those losing odds, the $0.50 premium on the bet swings the expected return back in your favor:
((13 * $1.50) - (14 * $1.00)) / 216 = $0.025
No :-(
Look again at the bet proposed in part 2 versus the question in part 1.
Re: No :-(
Is it related to the fact that in the first question, it was whether the other two matched the first, and in the second it is that any two match the third?
Re: No :-(
Exactly. And surprisingly, that changes the odds.
I meant "yes :)"
Solution -- A dicey one, part 2
Dan spotted the subtle but very meaningful difference between parts 1 and 2. In part one, we asked for the probabilities that the second and third dice thrown would add or multiply to the first. In part two, the guy offering the bet was suggesting a game to see if the three dice could be made to form a valid addition or multiplication. Surprisingly, that changes the odds significantly. In the first case, there are 15 ways of forming a valid addition versus 14 for product, and removing the 4-2-2 tie, we have 14:13 odds, nearly a tie.
In the second game, there are 45 ways to form a valid addition, and only 25 ways to form a valid product. Removing the three ties gives odds of 42:22, nearly a 2:1 bias toward the addition.
To better see what is happening, consider again three different colored dice (G,B, and R), and the cases where the "target" is three.
In the part 1 version, where the green die is cast first, there are two solutions for product:
G3B3R1 and G3B1R3
and two for sum:
G3B2R1 and G3B1R2
In the part 2 version, there is one additional solution for product:
G1B3R3
and four additional solutions for sum:
G2B1R3 G2B3R1 G1B2R3 and G1B3R2
The same table from part 1 could be updated with new counts, with that count being 1 if it is a triple roll, 3 for a double, and 6 if there are three distinct numbers. The result is the 45 and 25 counts given above.
Clarification
Dan, you hit the nail on the head there, but I do want to clarify one point lest anyone be confused. By "third" above, you meant what is left after choosing "any two", not the third die thrown. Your "choosing any two" makes your intent clear to me, but I wanted to avoid confusion, since if anyone read it as the first two adding to the third thrown die, we are back to the Part 1 version.
Good thing I'm not a gambler
Here I was expecting to make a killing at an expected return of two and a half cents per throw. Instead I would be losing $0.04167.
Thanks for the question.
Re: Solution -- A dicey one, part 2
I knew what was different, but was not smart enough to actually solve it ;-)
This is similar to the problem that says for a random group of people, hoe many do you need to have over a 50 % probability that two of them have the same birthday? (month and day)
Steven Antonucci
Missed the subtlety
However, I do have a good rule of thumb- If someone comes up to me with a bet, chance is always on their side!
Unless I have some way to alter the outcomes and influence or change them, I will never take the bet. I am trying to teach my kids this as well, and my son still falls for it almost every time...
Steve
And an excellent rule of thumb it is
Put another way, "Never bet against the house".
Steven Antonucci
Vegas was built on that!
