Humpday Triviola
Humpday Triviola
Humpday Triviola
Today I am looking for the correct term for any wood that meets this description:
Abnormal wood that often forms on the lower side of branches and of leaning trunks of softwood trees: it is identified by its relatively wide annual rings, usually eccentric, and its relatively large amount of summerwood, usually more than 50 percent of the width of the annual rings in which it occurs: it shrinks excessively lengthwise as compared with normal wood.
So what term is used to describe this sort of wood?
Tom
Re: Humpday Triviola
I would try to answer it now, but the reaction would probably be to put me in the box, so I won't.
I agree with Dan, but another name for it is "big box home store lumber"
BBHSL, I think that you have coined a new term ;-)
No to all above. plus hint
Not a box or big box store lumber or related term.
The term I'm looking for relates to the physical nature of the wood...hint.
Tom
Dale Lenz
Re: I'll either...
have a compression or tension thought on this question. Softwood has one of the two and hardwood has the other. Never can recall which wood is which. Thanks for the question.
Dale Lenz
Re: I'll either...
Conifers = Compression, ie C=C. Shoot, I'll forget by the time I need to know this again, : ' >.
;-) Answer
Wood that fits that description is called Compression Wood.
Nicely done Dale!
Tom
Dale Lenz
Re: BTW
Just FYI: reaction wood is the woody material that surrounds the pith of the tree. As a general rule, about the first 15 growth rings. The RW is subject to brashness and longitudinal shrinkage, I.E. bows end to end on the face plane.
When I order logs sawned up from my sawer I usually ask for the pith to be boxed, called boxing the heart, than tossed, unless I'm going to be charged for it than will take it home for dunnage/firewood.
Last time I had some wood qtr. sawn a few of the boards had the pith on one edge: got a "(" edge to edge. Will have pith removed prior to drying next time, if I don't forget, : ' >.
Dale Lenz
Re: Opps
Dan and the others were correct: Together compression and tension wood Are called reaction wood. The wood surrounding the pith is called juvenile wood, my bad.
BBHSL
I started to type "HD wood", but being from Atlanta, I didn't want to unfairly pick on our home-town boys. I'm not convinced that Lowes' lumber is any better. and I think our Canuckistan friends have other big boxes (Menards?) they love to complain about, thus the generic term!
