Tuesday Puzzle
Tuesday Puzzle
Tuesday Puzzle
A high school has a strange principal. On the first day, he has his students perform an odd opening day ceremony:
There are one thousand lockers and one thousand students in the school. The principal asks the first student to go to every locker and open it. Then he has the second student go to every second locker and close it. The third goes to every third locker and, if it is closed, he opens it, and if it is open, he closes it. The fourth student does this to every fourth locker, and so on. After the process is completed with the thousandth student, how many lockers are open?
Re: Tuesday Puzzle
Re: Tuesday Puzzle
Yes, that IS a very odd opening day ceremony. ;-)
Re: Tuesday Puzzle
Re: Tuesday Puzzle
My solution comes up with a surprisingly small number of open lockers, less than 40.
Re: Tuesday Puzzle
Re: Tuesday Puzzle
I got a little less than 10*pi, but without the circular reasoning!
Re: Tuesday Puzzle
ooops! I misread that.
The real answer is closer to the square root of the number of students.
Re: Tuesday Puzzle
Answer
As most figured out, the answer is 31.
Re: Tuesday Puzzle
Solution?
You're not really going to leave folks with just the answer and no clue to the how and why, are you?
Re: Tuesday Puzzle
Re: Solution?
About 6 lines of code in Matlab
Re: Tuesday Puzzle
No computer needed
Re: Tuesday Puzzle
Re: Solution?
The only lockers that remain open are perfect squares (1, 4, 9, 16, etc) because they are the only numbers divisible by an odd number of whole numbers; every factor other than the number's square root is paired up with another. Thus, these lockers will be "changed" an odd number of times, which means they will be left open. All the other numbers are divisible by an even number of factors and will consequently end up closed.
So the number of open lockers is the number of perfect squares less than or equal to one thousand. These numbers are one squared, two squared, three squared, four squared, and so on, up to thirty one squared. (Thirty two squared is greater than one thousand, and therefore out of range.) So the answer is thirty one.
