Tuesday Puzzle
The radius of the circle is 1. The triangle is equilateral. Find the area of each colored region.
Tuesday Puzzle
Re: Tuesday Puzzle
I believe I have solved it. I don't know that posting a numeric answer would spoil it for those still working on it, but just to hide it a little, I think the ratio Green:Orange:Yellow is 1:1.56:0.32
Re: Tuesday Puzzle
Been 45 years since I fooled with unit circles. Time enough to forget a lot.
Solution
Draw a line between the two points where all three colors meet. Then consider these three areas:
The circle: Area = pi
The small equilateral triangle: Height = 1.5, Area = 1.5^2 / sqrt(3)
The large equilateral triangle: Height = 2, Area = 2^2 /sqrt(3).
Then the areas in question are:
Green = 2/3 ( circle-small triangle) = 1.23
Orange = small triangle + Green /2 = 1.91
Yellow = large triangle - Orange = .40
Re: Solution
The area of the small triangle does not seem right.
I think it is 1.5*1.5/sqrt(3).
Re: Solution
Nikos, perhaps you are reading the ^ symbol as 'multiply'. I believe Alex is using it to mean 'exponent'. (It could be read either way in the next equation: 2^2). I believe you are using the * symbol as 'multiply'.
But using ^ as exponent, Alex's equation 1.5^2/sqrt(3) is the same as your equation 1.5*1.5/sqrt(3).
Correct
But if it shows up as clearly (not) on Niko's screen as on mine, the confusion could just be visual. I don't know another symbol as standard as "^" for "to the power". Maybe a double asterisk like I think some programming languages use?
