Monday's effort
Soon Spring will be here and we will be moving all that heavy stuff (tree branches, replacement shingles, the old Unisaw, etc.) we didn�t do in cold weather. Some of the time it will be to our benefit to have some sort of mechanical advantage when doing this work. Today�s trivia has to do with the application of force to move something. Blocks with multiple sheaves figure in to today�s trivia.
Given: Force = Weight/Number of lines.
What is the mechanical advantage of attaching a line to an object and then passing that line through a solidly anchored single pulley to move a load?
How many changes in direction of a similarly anchored line will appear between two multiple sheave blocks to increase the mechanical advantage six times?
The amount of friction (rule of thumb) percentage that must also be taken into account when planning moving something using multiple sheave blocks and a fiber (not steel) line load is 10% per sheave.
load (to the nearest American (short) ton) of a three fold purchase (three sheaves per block using two blocks), including friction, using a line whose working load is rated at 4000 lbs.?
