Friday puzzle -- visualize this
A certain overweight geometer went to a donut shop and ordered his normal breakfast of coffee and a donut. However, to lose weight, he decided to put artificial sweetener in his coffee, and play mental games with the sugar cube (a 1cm cube) and donut (a perfect torus of 3" outside diameter and a 1" hole).
Part 1.
He noticed that if he cut the cube in half with a horizontal cut that the face of the cut piece would be a 1 cm square, but that if he cut vertically through a diagonal of the top face, the face of the cut would be a rectangle 1 cm wide and sqrt(2) cm long.
Hmm, he thought, if I cut it like this, the face of the cut would be a perfect hexagon. Describe that cut, and the size of the hexagon.
Part 2.
He then turned his attention to the donut, and noticed that if he cut it in half vertically, the cut surface would be two disjoint 1" diameter circles (filled with pastry) 1" apart, and if he cut it in half horizontally, there would be concentric 1" and 3" diameter circles, with a ring of pastry between.
After some consideration, he decided there was a way to cut the donut so that the outside edge of the face of the cut would be two intersecting circles. Describe that cut and the size of the circles.
P.S. if anyone here is handy with solid modeler software, they might prove that "a picture is worth a thousand words" in giving the answer. But try it as a mental exercise first.
