Tuesday Puzzle
Tuesday Puzzle
Tuesday Puzzle
Which of the following is the odd man out?
A. 764345986
B. 125612456
C. 367874341
D. 456578325
E. 178652457
F. 279651238
Re: Tuesday Puzzle
Re: Tuesday Puzzle
To be or not to be.
Lee
Re: Tuesday Puzzle
Re: Tuesday Puzzle
I don't get Lee's answer. This may be a prime example of where we each see something different.
Re: Tuesday Puzzle
Re: Tuesday Puzzle
Don't get Lee's answer, but as far as I can tell, neither of you are correct.
Re: Tuesday Puzzle
Re: Tuesday Puzzle
If I was from NY, MI, TX, PA, or OH would I know the answer?
Re: Tuesday Puzzle
Bad guess, but _A_ right answer at least.
I suspected that C was the only prime among these numbers. But after seeing your reply, I checked an online calculator and found out C is the product of 2,039 and 180,419. But C _IS_ the odd man out in having no single digit prime factors.;-)
Re: Tuesday Puzzle
Re: Bad guess, but _A_ right answer at least. (hin
We will give a star for that one, but there is another reason that one of them is odd one out and it does not require any calculation or exotic knowledge (not that primes are exotic, but...), just simple observation.
Re: Tuesday Puzzle
possibly, if I read your answer correctly.
However, they would not be an exact analog.
Re: Tuesday Puzzle
Re: Tuesday Puzzle
Actually I had no idea, so I figured I had a 1 in five chance of picking the right one. I picked B because at first glance , until I read the numbers closely, it looked like a repeating series number of 12561256.
Lee
Re: Tuesday Puzzle
Re: possibly, if I read your answer correctly.
A would be odd man out, if my theory is correct.
Re: Tuesday Puzzle
Re: Tuesday Puzzle
Choice F doesn't have any repeating numbers in it. All the others repeat at least one number. Could that be the solution?
Fred
Re: Tuesday Puzzle
No
Re: Tuesday Puzzle
no, but
on the right track. ;-)
Re: Tuesday Puzzle
Re: Tuesday Puzzle
If you look at it long enough, you can probably find something unique about all of them.
A is the only one that starts off with a negative trend.
B is the only one without a 7 or 8.
C is the only one with no 5.
D is the only one with 3 of a kind.
E has the largest inter-digit gap
F has the most unique digits
Re: Tuesday Puzzle
answer
As stated, you can probably find a lot of differences, but if you look, E is the only one that does not have 3 digits in series somewhere in it.
