Jedi Mind Trick
Jedi Mind Trick
Jedi Mind Trick
This little Jedi mind trick is kinda freaky, till you think about
it a little while. Then it's even more weird. Just follow the
instructions below
DON'T scroll down too fast-do it slowly and follow the instructions
below exactly, do the math in your head as fast as you can. It may
help to say the answers aloud quietly.
FOLLOW these instructions one at a time and as QUICKLY as you can!
What is
. 2+2?
. 4+4?
. 8+8?
. 16+16?
. Quick! Pick a number between 12 and 5.
. Got it?
. Now scroll down...
. The number you picked was 7, right?
. Isn't that weird???
Free will or synaptic wiring? You be the judge.
Check out the following exercise, guaranteed to freak you out.
There's no trick or surprise. Just follow these instructions, and answer
the questions one at a time and as quickly as you can!
Again, as quickly as you can but don't advance until you've done each of
them...really. Now, ARROW down (but not too fast, you might miss
something).........
. What is
. 1+5
. 2+4
. 3+3
4+2
. 5+1
Now repeat saying the number 6 to yourself as fast as you can for 15 seconds.
Then scroll down.
. QUICK!!! THINK OF A VEGETABLE! Then arrow down.
. Keep going.
You're thinking of a carrot right?
If not, you're among the 2% of the population whose minds are
warped enough to think of something else. 98% of people will
answer with carrot
when given this exercise.
Freaky, huh?
Please report your results on the board.
Re: Jedi Mind Trick
My answers are below
Sorry but I came up with 9 and peas. But I have been told time and again that I have a warped mind.
Lynn
Re: Jedi Mind Trick
Dale Lenz
Re: Batted 1000,
7 & carrots, yes it's strange, but I keep telling my wife I'm normal, : ' >. Thanks for the question.
Re: Jedi Mind Trick
Re: Jedi Mind Trick
Eight & pea. I must be one of the 2% then? Not necessarily a good thing. ;)
Re: Jedi Mind Trick
Re: Jedi Mind Trick
11 and potato. I must be really weird ;-)
Re: Jedi Mind Trick
Re: Jedi Mind Trick
7 and tomato, I must be only half... something
glc
Re: Jedi Mind Trick
Steven Antonucci
6 and lettuce? Go figure, I'm in the 2%...:-)
Re: Jedi Mind Trick
Steven Antonucci
Try this one:
Think of a number between 1 and 9.
Subtract 5 from the number.
Multiply the difference by 3.
Square the product (multiply the product by itself).
Add the digits of the new number.
If the sum isn't a 1-digit number, add the digits of the new number together. Keep adding the digits of each new sum until you get a 1-digit number.
If the new 1-digit number is less than 5, add 5 to it. If it's greater than 5, subtract 4 from it.
Multiply the difference by 2.
Subtract 6 from the result.
Think of the letter of the alphabet that corresponds to this new number. (A=1, B=2, etc.)
Think of a country that begins with that letter.
Think of an animal that begins with the second letter of the country's name.
Think of the animal's color.
Think of a fruit that begins with the first letter of the animal's color.
Scroll down
Why was the elephant eating grapes in Denmark?
S
Re: Jedi Mind Trick
Thoughts on responses
1) Dale and I are the only "normal" folks reading this ;-) (Gary's half-normal)
2) Seriously, I wonder if there was a problem in the way I transcribed it, or if we really are a different group--this is usually more dependable.
3) Here's what I think is happening in the first one, at least for Dale, Gary, and me (and others I have tried this on). First we get into arithmetic mode. Then we are asked to pick from the range of 12 to 5. The conscious brain says "Whoa, what is happening here? Ranges are always given from low to high. Okay, so I guess it is just asking for a number between 5 and 12." Meanwhile, the unconscious brain is saying "We are working on arithmetic here. The last one was not an addition. A larger number followed by a smaller one looks like subtraction, which would yield 7" These two trains of thought end at the same time, the conscious brain hears what the subconscious is working on and says "Yeah, that'll work. 7"
That's my theory and I'm sticking to it. I'll leave it to Dale to explain carrots to the unenlightened! ;-)
Thanks for playing.
Re: Jedi Mind Trick
Re: My answers are below
9 and peas here too. He must have forgotten to say that "9 and peas" takes you way past the mundane, average, normal thinking. :)
Re: Jedi Mind Trick
Re: Try this one:
Step 8: What difference?
Here's a simpler one along the same lines:
Think of a number between 1 and 10.
Multiply the number by 9.
Add the digits of your result.
Subtract 5 from your new number.
Find the letter that corresponds to your number, if 1 = A, 2 = B, 3 = C, etc.
Think of a country that begins with your letter.
Write down the name of that country.
Think of an animal beginning with the second letter of your country.
Think of the color of that animal.
Write down the animal and its color.
Think of an animal that begins with the last letter of your country.
Think of a fruit that begins with the last letter of this second animal.
Write down the fruit and the animal.
Re: Jedi Mind Trick
Close
Only my elephant was eating guavas. Lynn
Re: Jedi Mind Trick
Dale Lenz
Re: Don't get me to lying, : ' >
Re: Jedi Mind Trick
Re: Jedi Mind Trick
11 & egg plant. Hmmm. I must be in the warped group. Nothing new there!
Cheers!
Jim
