Tuesday Puzzle
Tuesday Puzzle
Tuesday Puzzle
Here is another puzzle for you:
Cube game: We have a set of 4 cubes with a different letter on each face, making a set of 24 of the letters of the alphabet, including "J". You make words by setting up the cubes so that you make common 4 letter words on the top face of the 4. The following words were made using this set of cubes. Can you figure out what letters are on each of the 4 cubes?
1. CAVE
2. CLEF
3. DUPE
4. FARE
5. FLUB
6. GREW
7. HAZY
8. KITH
9. LOIN
10. POEM
11. RASP
12. SMUG
13. TIRE
14. VARY
Re: Tuesday Puzzle
Jeez, start, or rather where to start.
I'm not sure I'd want to be your student. Since no letter repeats and there are 24 letters that means from the list that Q and X are not included. And for sure, one face of the four blocks has to have as one of the faces a 1C,2A,3V,4E. No other block can contain those letters so this is to be a problem of elimination. I need a grid of four columns with six rows. And I need a big eraser. Also from the list P and A cannot be on the same cube, nor F and A. And F can�t be on the same cube as C or with E. W cannot be with blocks that have E, R, or G. K cannot be with I, T, or H. H cannot be on the same block as A,Z, or Y. U has to be on a different block than F,L, or B. It's the matchups I'm missing. This will take a while.
Re: Tuesday Puzzle
Re: Tuesday Puzzle
ADLMTW
BEKNSY
CHJOUR
FGIPVZ
Re: Tuesday Puzzle
More time I cannot spend
Cube 1 C and R and U= flub or B?)
Cube 2 A and L (S or P?)
Cube 3 V and F (S or P?)
Cube 4 E and (B =flub or U?)(Y works if U is on one)
So far so good but only nine of 24 seem to fit all the time and I'm confusing myself each time I go back for verification. It should be getting easier, but I now am questionioning all but the first four. This is stranded on island thought.
Cave
Clef
Fare
Flub?
Vary?
Rasp?
Re: Tuesday Puzzle
Thanks for playing.
Re: Tuesday Puzzle
Ed , I went bonkers.
Congrats. How did you break it out? What guided you to lead with ABCF and DEHG? I couldn't get to some of those letters in column two or especially three - LKJI. Did you make a matrix?
Re: Tuesday Puzzle
Re: Ed , I went bonkers.
"What guided you to lead with ABCF and DEHG?" I didn't. I started with CAVE and rearranged the letters alphabetically after solving (easier for Dan to check). :)
"Did you make a matrix?" Yes, I started with a grid of text boxes (in QuarkExpress just because I have it and use it daily), 4 wide and 7 high, thusly:
[C] [A] [V] [E] cave
[_] [fl] [fl] [_] clef
[fr] [_] [fr] [_] fare
which tells me:
[R] [L] [F] [_] and so on ...
Re: Tuesday Puzzle
Thank you.
