Thursday trivia
Here is an easy one. the picture is kind of small, but hopefull big enough to see. What is this?
Thursday trivia
Re: Thursday trivia
I've been trying to figure it out but my tired old brain just locked up. Tom
Re: Thursday trivia
Is it kin to a sun dial? Thanks for the question
No, but (hint)
it might be appropriate for the season. The background for it is a hint.
Re: No, but (hint)
It's a brick powered time machine? Wow...cool!!
T.
Re: No, but (hint)
The background for that image, which turns out to be actually smaller than the preview image, appears to be Fresnel Lenses or Prisms. Might this be a clock-work mechanism (noting the two lines extending below it that might go to weights) for turning the lamp in a lighthouse?
Fred
Gray and rainy in Eastern Missouri
Now that's it late in the day...
And I can't think of any snappy responces. It look like a door latch or lock of some sorts.
Re: Thursday trivia
I suspect it's the drive mechanism (hoist)for a dumbwaiter.
Re: No, but (hint)
Might be that my monitor is set too bright. Those ARE brick in the background. In that case, you got me. Although it does look like something for cranking up the string that appears to be hanging below it.
Fred
Dark and overcast in Eastern Missouri
Re: Thursday trivia
It is a drive mechanism, but not for a dumbwaiter. The background is a hint. Think of something that is normally made of brick. (at least in older times) The name is two words, the first is related to what some thought it looked like and the other might have an application to your car.
Re: No, but (hint)
Partly right, but no lighthouse ;-)
Re: Thursday trivia
First automatic garage door opener--hand powered--for brick doors?????????
Uhh.......... no ;-)
Lemme noodle
Supporting rods or weight cables toward the ground--Mounted on brick wall--turns stuff--crank with spring mechanism--for the season (spring through fall?)--are we cooking something? I can't make a connection to the car though--unless it's a grill.
Close enough
This is close enough. It is a clockwork mechanism for rotating a spit over a fire for roasting. It is called a clock jack.
Re: Thursday trivia
Is it an oven door?
