What is the only woodworking tool...
that has the same name as what it produces. Hint: the tool and its result are called by the same name.
Stephen
Stephen
Re: Router?
Re: What is the only woodworking tool...
A filletster plane produces a fillet, a rabbet plane produces a rabbet, a dado blade produces a dado, a spokshave produces shavings-am I on the right track or just WAG'in ?
Close but no cigar, hint: it is a handtool
Quirky question...
I'll have to router around for the answer.
WAG
Spill plane?
Lynn
A plane produces a plane (a flat or co-planar surface)
I'm gonna guess a scratch bead?
Tom
hint
I was going to post the answer then I thought of another tool that almost qualifies as the answer but not quite. The other tool produces a 'chime' and something else that is also the name of the tool. This is actually a hint.
Stephen
Well This Shaver produces Shavings!!
Do I win??
Take care,
Jim
A plumb bob makes plumb lines, a chalk line makes chalked lines, a straight edge finds straight edges, and a mortiser makes mortises.
Answer to the hint
The answer to the hint is a 'howel' which makes a chime and a howel.
Stephen
Gouge?
Are you saying your a woodworking TOOL?
Ask your kids if you want to refer to yourself as a "tool" :-)
I think it has a negative connotation in today's vernacular.
Steve
Answer
You folks had some good responses but the tool I was looking for is used in barrel making and it is called a "croze" and it produces the kerf on the ends of the barrels to hold the barrel heads and the kerf is called a 'croze'.
Stephen
Re: Answer
Isn't the tool that makes a quirk called a quirk? (per the answer above.)
quirk plane, two words :-{
Dictionary of Tools
Hate to burst your bubble, but the tool you are refering to is properly called a "cooper's croze plane". Most people would drop the cooper's and some would drop the plane.
Oxford Universal Dictionary
Croze - The groove at the ends of cask staves, etc., also, the tool for making it.
Stephen
Re: Oxford Universal Dictionary
what about a chalk line?
