Friday Filler
Friday Filler
Friday Filler
This one might be a bit more difficult (or then again, maybe not ;-))
I was doing a bit of reading on some mathematics sites and ran into a reference to the attached picture. I looked it up and thought that it might be an interesting trivia question. There is some connection to woodworking as at least a form of it is used in the furniture industry. (probably not exactly as pictured)
It was patented in the early 1900's and there is still a company bearing the inventors name in existence today that makes them.
The questions are:
1) What is it called
2) What does it do?
Just as a reference, the shape in the lower part of the picture is the profile of the bottom part of the tool.
For extra credit, that profile is a modified version of the actual mathematical version. What is this version called and where else might you see it? (completely different application, although I am sure most have heard of it.)
Confused enough yet? ;-)
Here is the picture:
Re: Friday Filler
Dale Lenz
Re: What is does?
I'll guess it produces an oval cut on the surface of wood. Might be used in "carved molding" ?
Thanks for the question.
Re: Friday Filler
Re: Friday Filler
Or an impeller for a dust sucker?
Re: Friday Filler
Re: Friday Filler
I'm gonna guess that it is the legendary Ronco Finger Remover? ;-)
Tommy
Re: Friday Filler
Steven Antonucci
It's the blade assembly to the Bass-O-Matic
Mmmm- that's good bass!
Steve
Re: Friday Filler
Re: Friday Filler
It looks like a messed up sinusoid to me.
Re: Friday Filler
Sorry ;-(
Re: Friday Filler
uhhhhhhhhh....No
Re: Friday Filler
Nope
Re: Friday Filler
A bit closer, but not quite. (hint(s))
Maybe think of a steam powered Mazda.
Re: Friday Filler
Steven Antonucci
Made it a little too easy
Inner workings of a rotary engine.
Steve
Re: Friday Filler
Partway there, but
There is a relationship to the rotor shape of the Wankel engine (but what is the shape called? ;-), but now, what does this particular tool do, and what is it called? Another hint: I found the reference to this tool while doing some reading about the math related to the shape of the rotor. There is also another hint in the above message. You only got one of them ;-)
Re: Friday Filler
Re: Partway there, but
Square holed mortises.
Ruleaux (sp?) triangle.
Re: Friday Filler
