Monday , in the clouds
I shall be on travel until Monday evening. Answers then. Here is the second group questions concerning lighter than air ship trivia.
The Hindenburg had a volume of 7,062,000 cubic FEET. When filled with hydrogen anyone care to hazard a guess how much was its gross lift? By comparison, today a 747 can lift 400 tons but uses about 64,000 gallons of fuel to do it. Note: All things being at standard temperature and pressure (STP) my numbers arrive at 1 cubic METER of hydrogen gets 1.2 pounds of lifting force.
Hydrogen is odorless. There was a low tech way to know if there was a leak (and no fair saying seeing �fire�). Hydrogen flames are invisible. Germany used one way. NASA (in the 1960�s no less) came up with a way to test No joke. What was their answer to avoid being fried by hydrogen flames? (If you don�t know you won�t believe this one).
The Hindenburg was originally designed to use helium. Why didn�t the Hindenburg use helium? Helium was four times as expensive as hydrogen but cost wasn�t the reason. As it was, it was an expensive proposition as hydrogen fill up costs were expensive. At an average $9 per 1000 cu ft, what did it cost to do the initial fill up in 1937?
Where did the name �blimp� come from? (Hint: It was rumored to be from Britain.)
What was the top speed of a Zeppelin type ship? For about the same price as a cruise ship how much time was saved on a trip Europe to United States? England or France to New York (ship) vs. Frankfort to Lakehurst, New Jersey (airship).
Re: Monday , in the clouds
Sounds like you were recently in Tillamook, visiting the blimp hanger.
As I recall, NASA's hydrogen leak detector was a common household item.
Low hanging fruit and a wag ...
Well, I'll take a stab at the low hanging (math) based questions!
7,062,000 cubic feet should convert (if I'm using the right mtr/ft values) to 199,973.57 cubic meters which should give 239,968.28 lbs of lifting force (@1.2 lbs / m3)
Of course, the cost for a "fill up" at 9$/1000 ft3 would be $63,558 -- no small change back then!
As far as the detection of leaks, I'm guessing one of those parties used the same method I use for checking propane leaks in the bbq? The last thing you want are tiny bubbles ;-)
Another wag is I would guess that Hydrogen has a higher lifting power than helium?
Thanks for the question!
-Randy
Why not Helium?
I know the answer to this one, but the goverment won't let me tell it to you.
glc
Re: Why not Helium?
It makes you talk funny.
Re: Monday , in the clouds answers
Answers:
DB I haven�t been to the Oregon museum --but I know about it and did attempt to find out how much WOOD was used to make the hangar-no joy there. There�s a question for someone!
Bill Earl gets credit for the broom.
Gary gets the government holdback helium star, and Randy Miller I got you at 119.98 tons lift. And gas fill up dead on. Winners all
Math whizzes get to push me around here but basically you can take cubic feet and convert to cubic meters which are 35.315 cubic feet per cubic meter. 7,063,100/35.315=200002.8 sq meters x 1.2 lbs=
240003 lbs lift/ 2000 = 120tons This is apparently the useful lift. However the volume of the Hindenburg 882 feet x 135 feet max diameter was according to one web report (www.ciderpresspottery.com) 242 tons without all the structure. All in all I get 115 to 120 in the reading material. Not bad even for today.
The Germans used garlic smell to tell if hydrogen was leaking. NASA on the other hand told their employees to walk around with a broom held in front of them to discover if hydrogen was aflame.(seriously!)
Helium supplies were largely �owned� by the US govt. and we wouldn�t give it to them. There were cost and transportation/delivery problems to be sure but it was the Nazi swastika painted on the tail that shut them out of helium for good. Germany didn�t flinch. The lifting ratio between helium and hydrogen is slightly under 10% actually 25/27. They added ten staterooms because of the extra buoyancy and went on their merry way. (After all they had 30 years experience with hydrogen �even in wartime as a bombing platform�Opps could that have been the reason not to give them helium?�the possibility of bombs over New York-hmmmmm(Sounds like Japan in WWII)). Anyway a cheap fill up was $63,558 in 1937 dollars and in corrupt Spain the fees were $35/1000 cubic feet, not $9.
Aside: Because of the expense, pilots were told not to dump gas if the ship became light. They were to fly into fog or clouds to cool them down (are you kidding me!�INTO clouds with an explosive gas), or wait till night, or drive the ship to the ground using engines so that a ground crew in the hundreds sometimes could wrestle it to a stop and add sandbags and water
Blimp (a blimp is not a rigid or semi rigid air ship by the way)got its name from a British military guy who said it was the sound of a finger held back by the thumb and suddenly released. When it hit the skin of the non-rigid ship it went �blimp.� Lt. A.D. Conningham of the British Royal Navy in 1915 gets credit at least some of the time.
A cruise ship took a little over four days. The airship could do it in 2 1/2 at a top speed of 85 MPH. Driven by four 1200 horse Mercedes Benz engines and four 20 foot four bladed props. Not nearly as posh as a ship however as the walls were thin, and fifty people shared one shower.
