Thursday Trivia
Thursday Trivia
Thursday Trivia
At one time, this tree was described from fossils and thought to be extinct. Then, a small stand of trees was found that turned out to be living versions of the fossils. It is the only living species of its genus, but several fossil species are known.
It has needles, but is deciduous. The lower trunk tends to become buttressed as the tree gets older. (hmmmmmm, I wonder if I am related. My middle trunk is becoming buttressed as I get older ;-)
At any rate, what tree is it?
Re: Thursday Trivia
Re: Thursday Trivia
That sounds like a tree I have in the backyard. It is always losing its needles. If it does not become green soon I will have to pull it out.
Re: Thursday Trivia
Re: Thursday Trivia
Hmmmmmm........this is a good one...hmmmmmmmmmmmm
Take care,
Jim
Re: Thursday Trivia
Re: Thursday Trivia
I certainly could not get one home in an MG...unless it was a sapling. ;-)
Tommy
Re: Thursday Trivia
Re: Thursday Trivia
It just dawned on me that you're asking about a tree that I planted over thirty years ago in my back yard in central Ohio. It's now about 4' diameter at the base, but quickly tapers to probably 2' dbh. I'm not a carver, but I played around with a branch making a walking stick, and I believe you carvers out there wood love this wood. It is fine grained,easily carved, and takes detail extremely well.
Re: Thursday Trivia
Dale Lenz
Re: Thursday Trivia
You talking about the stand of trees Down Under?
Thanks for the question....Dale
Re: Thursday Trivia
If it is what I thinking...
Dave Smith gave me a piece a few years ago. It'll dawn on me sooner or later where we had that get together.
glc
Re: Thursday Trivia
not down under.
A couple of the answers know what it is.
Re: Thursday Trivia
The answer *LINK*
As several have noted, the answer is the Dawn redwood or Metasequoia glyptostroboides
Here is a bit more info about it and a link.
* leaves are deciduous
* opposite arrangement on branchlets
* 0.5" long, linear, flat leaves
* stems are either persistent or deciduous
* deciduous stems are green and are held on brown, persistent stems
* deciduous stems, have needles, but do not have buds
* persistent stems hold deciduous stems, some needles and oppositely-arranged buds
* deciduous stems drop in the fall with the needles
* foliage is medium to bright green
Dawn Redwood
