Monday, end of year vocabulary
Match em up.
Put one from column A with its basic companion explanation in column B. There are more items in Column A than in B so there is no perfect match one for one. In cases of differing opinions think of me as Solomon.
Column A                  Column B
Rake                       notch in rafter
Cripple                    angle of slope
Header                     temporary load
Shake                      edge
Persuader                  chisels for cleaning mortises
Wing wall                  chisels for framing
Caliper                    cross section of timber frame
Swans                      mallet
Slicks                     distance measurer
Caisson                    horizontal beam
Girt                       retains soil
Bent                       piling support
Arris                      place where chords intersect
Truss                      short studs
Heel                       assembly of members to form a framework
Girder                     separation of wood along grain
Live load                  trunk of tree
Dead load
Bird�s mouth
Bole
Deadhead
Re: Monday, end of year vocabulary
Sorry for the appearance, it looked fine
when it was prepared. It transferred from Word nicely. Only in post did things change. My apologies.
Here is how to do it;-)
If you have some text that is formatted in columns or something that you want to post, here is how to do it.
There is a tag for preformatted text where the formatting is preserved.
The format is:
<pre>
Put your formatted text here
</pre>
Here is an example:
Column 1            Column2
Stuff in 1            stuff in 2
More stuff            more stuff
A few guesses
Here are a few guesses. No Google invilved, just guesses ;-)
*Rake                        angle of slope
*Cripple                    short studs
*Header                     horizontal beam
*Shake                      separation of wood along grain
*Persuader                  mallet
*Caliper                    distance measurer
*Swans                      chisels for cleaning mortises
*Slicks                     chisels for framing
*Caisson                     piling support
*Arris                      edge
*Bird�s mouth               notch in rafter
*Bole                       trunk of tree
Answers for vocabulary. HNY 2006
Rake--angle of slope
Cripple--short studs
Header--No answer, as I was thinking of a curved or arched door or window as an exclusion. Dan was mostly correct (horizonal beam) so gets at least partial credit.
Shake--separation of wood along grain
Persuader--mallet
Wing wall--retains soil (usually on shores of bridge)
Caliper--distance measurer
Swans--chisels for cleaning mortises
Slick--chisels for timber framing
Caisson--piling supprot
Girt--horizonal beam (mosly used in timber framing)
Bent--cross section of timber frame
Arris--edge
Truss--assembly of members to form a framework
Heel--place where chords intersect (used mostly in circular roof construction)
Girder--no answer
Live load--temporary load often on roofs (snow, for example)
Dead load--no answer
Bole--trunk of tree (forestry)
End of year vocabulary - My SWAG
Rake angle of slope
Cripple short studs
Header
Persuader mallet
Wing wall
Caisson
Girt cross section of timber frame
Bent piling support
Arris edge
Truss assembly of members to form a framework
Heel place where chords intersect
Girder horizontal beam
Live load temporary load
Dead load
Bole trunk of tree
Deadhead retains soil
