Monday, Baby it's cold outside
The image of an igloo as a temporary home seems to be known to all of us. There are lots of interesting facts about the igloo as a home, not the least of which is that it is a extremely well designed shelter. But how is a residence, built in under two hours with little but a flat stick built to withstand a nine foot tall polar bear standing on its hind legs and attempting to crush it to reach the objects it can plainly see inside the translucent shelter. How can this be?
Re: Monday, Baby it's cold outside
The Key to strength of the structure is above me.
Arctic Feng Shui
The harsh arctic winter is stressful to the polar bear. As everyone knows, a stressed out polar bear makes a poor house guest. The shape of these Domiciles helps to dissipate that stress.
Weight Bearing Snow
Much like stone arches, arches are extremely strong structures. Perhaps the builders of cathedrals in Europe were Eskimos?
Tommy
So far none are incorrect but
I want more. Snow blocks forming a arch is certainly key to the build but not strong enough. The snow key formed block(s) on top is also important but again not capable of withstanding a seven foot tall up on hind legs hungary animal weighing several hundred pounds. I thought that Bill's feng shui answer might refer to the direction the igloo faced as well as the shape and that too is important, but not what will make it last as a living quarters.
Re: So far none are incorrect but
The inside information is that they're only snow forts until you add a little hot/cold running water ;-)
Trick Question
This is a trick question. Igloos are a beacon to polar bears who delight in smashing them and making popsicles out of frightened Eskimos. For what it's worth, igloos cannot stand up against Godzilla either.
Tommy
Answer
Not a trick question. Randy got it dead on. Several points come to mind. One, the shape of the arch is important. Igloos work better as a catenary arch (St. Louis arch shape) than would a cartoon drawn half sphere shape. The inuit used intuition not physics. In this way the line of thrust follows the arch and not thrust outwards as would a half sphere. There are no compression rings or flying buttresses around a temporary igloo. 2nd, The inside of the igloo is well based because a good portion of it is hollowed out (leaving a sleep shelf) of the existing grade. The snow blocks removed in the excavation then make up a portion of the walls beginning one quarter to about half way to final height. This makes it easier to build for the rise, but also it provides a solid undisturbed perimeter foundation for the spiral courses of snow blocks. 3rd, once up, the inside should be smoothed from the rough cut snow blocks. Smoothing on the inside will allow for the most critical step, which is to build a controlled fire inside the shelter (don�t forget to vent, but not dead center). The rising heat builds up and will cause the snow to melt and run smoothly down the sides of the shelter without dripping. This moisture is initially wicked by the snow towards the outside of the shelter to freeze but while that is occurring the fire is banked and the door opened. Thus you get flash frozen windproof walls. Pardon the pun but pretty slick, no? In effect you get what amounts to an ice egg shell with compression strength routed directly to the unmoving undisturbed ground. If an igloo is going to be used for a prolonged period of time one must make the igloo base as round as possible and the blocks must be placed properly. When the igloo has been completed it must have a TAJJUTAQ. TAJJUTAQ is an additional low wall of snow blocks built around the outside wall of an igloo used for long term habitation. The space between the two walls is filled with loose snow. It makes the igloo interior darker during the day, but warmer all the time. As to bears they havd been known to show up but they normally alert the animals, or first follow scent to the tunnel which brings firearms into the mix. (Joke: Why do bears like igloos for snacks? Because it's crunchy on the outside and chewy on the inside) Finally, for Tommy I did a brief search as to polar bears attacking humans. 1. Polar bears are exclusive meat eaters. 2. Full grown bears have stomachs that can hold 150 lbs. But acording to the net recently in all of Canada, only six people have been killed by polar bears in the past 25 years. In the U. S. (Alaska) during the same time period, only one person was killed. In all of "recorded history", only 19 people have been killed by polar bears in Russia. In all instances in which a person was killed by a polar bear, the animal in question was starving or had been provoked. Polar Bear info: http://www.polarworld.com/polarfaq.asp
Thanks, Gary! Great Question!
In Feb '88 I stood inside a very large igloo built lakeside at Chateau Lake Louise in Alberta. I'm sure it was not a typical native structure, but I was struck by the immediate rise in temperature inside even though there was no fire. The heat from 5 or 6 people inside the structure was captured and retained (IIRC, there was no smoke hole or other roof opening) so efficiently that it was uncomfortable to remain inside without removing one's coat. The experience gave me a profound respect for the people who derived the design and used it so effectively.
Thanks, again, for a great question.
BobH
Polar Bear Warning.
The Alaska Department of Fish and Wildlife is advising hikers, hunters, anglers, and golfers to take extra precautions and keep alert for polar bears while in the wilderness.
They advise people to wear noise-producing devices such as little bells on their clothing to alert, but not startle the polar bears unexpectedly. They also advise the carrying of pepper spray in case of an encounter with a polar bear. It is also a good idea to watch for fresh signs of polar bear activity.
People should recognize the difference between small young polar bear and large adult polar bear droppings. Young polar bear droppings are smaller and contain fish bones and possibly seal fur. Adult polar bears droppings have little bells in them and smell like pepper spray.
Dan.
