Feelin Fat Monday
Where would an eighteenth century person who wanted to find a try pot be? What is a try pot?
Feelin Fat Monday
Re: Feelin Fat Monday
He would be far out at sea, blubbering away
Not always as ...
it happened on land whaling stations too, but correct.
If you care to read Moby Dick our "historian" Melville writes,
"Besides her hoisted boats, an American whaler is outwardly distinguished by her try-works. She presents the curious anomaly of the most solid masonry joining with oak and hemp in constituting the completed ship. It is as if from the open field a brick-kiln were transported to her planks.
The try-works are planted between the foremast and mainmast, the most roomy part of the deck. The timbers beneath are of a peculiar strength, fitted to sustain the weight of an almost solid mass of brick and mortar, some ten feet by eight square, and five in height. The foundation does not penetrate the deck, but the masonry is firmly secured to the surface by ponderous knees of iron bracing it on all sides, and screwing it down to the timbers. On the flanks it is cased with wood, and at top completely covered by a large, sloping, battened hatchway. Removing this hatch we expose the great try-pots, two in number, and each of several barrels' capacity.
Removing the fire-board from the front of the try-works, the bare masonry of that side is exposed, penetrated by the two iron mouths of the furnaces, directly underneath the pots. These mouths are fitted with heavy doors of iron. The intense heat of the fire is prevented from communicating itself to the deck, by means of a shallow reservoir extending under the entire inclosed surface of the works. By a tunnel inserted at the rear, this reservoir is kept replenished with water as fast as it evaporates. There are no external chimneys; they open direct from the rear wall. And here let us go back for a moment...Here be it said in a whaling voyage the first fire in the try-works has to be fed for a time with wood. After that no wood is used, except as a means of quick ignition to the staple fuel. In a word, after being tried out, the crisp, shrivelled blubber, now called scraps or fritters, still contains considerable of its unctuous properties. These fritters feed the flames. Like a plethoric burning martyr, or a self-consuming misanthrope, once ignited, the whale supplies his own fuel and burns by his own body. Would that he consumed his own smoke! for his smoke is horrible to inhale, and inhale it you must, and not only that, but you must live in it for the time. It has an unspeakable, wild, Hindoo odor about it, such as may lurk in the vicinity of funereal pyres. It smells like the left wing of the day of judgment; it is an argument for the pit.
By midnight the works were in full operation. We were clear from the carcass; sail had been made; the wind was freshening; the wild ocean darkness was intense. But that darkness was licked up by the fierce flames, which at intervals forked forth from the sooty flues, and illuminated every lofty rope in the rigging, as with the famed Greek fire. The burning ship drove on, as if remorselessly commissioned to some vengeful deed....
The hatch, removed from the top of the works, now afforded a wide hearth in front of them. Standing on this were the Tartarean shapes of the pagan harpooneers, always the whale-ship's stokers. With huge pronged poles they pitched hissing masses of blubber into the scalding pots, or stirred up the fires beneath, till the snaky flames darted, curling, out of the doors to catch them by the feet. The smoke rolled away in sullen heaps. To every pitch of the ship there was a pitch of the boiling oil, which seemed all eagerness to leap into their faces..."
