Tuesday filler
Tuesday filler
Tuesday filler
I am looking for a substance that is related to the pollination of plants and also to events that typically happen to trees at this time of year. It is an 11 letter word.
Re: Tuesday filler
Re: Tuesday filler
Chlorophyll?
11 letters, but I don't see the flower relation. I don't remember the name of the chemical that starts the reaction that changes the leaves, but I thought it was a 67 letter word. Is this what you mean?
Brian in Brighton
Re: Tuesday filler
No
Not that one. It does not necessarily have to do with flowers, but perhaps with color;-) Also not the chemical that starts the falling process.
Re: Tuesday filler
Re: Kan't spelling it with out looking it up
but may be caratene or gibabrellam. Are talking about a hormone here, Dan?...Thanks for the fill in.....Dale
Re: Tuesday filler
close.
It is responsible for a color, but not orange;-)
Re: Tuesday filler
You mean the hormone that causes envy?
Re: Tuesday filler
Dale Lenz
Re: How close do I need to get...: ' )
I pulled a pamlet out of my desk drawer about fall colors... Need to study up on it anyway for those expected calls in about a month here or sooner. Are talking about the reds and purple pigments that is responsible due to Antho_ _ _ _ _ _ _ (ending sounds simular to a well know poison).
Re: Tuesday filler
They are present even before the leaves "turn" and cause the leaves to radiate at a light frequency that we cannot see, but insects can. In some plants, the amount even varies depending on whether it is time for pollination or not.
When the chlorophyll goes away in the fall, the reds etc. become visible.
Re: Tuesday filler
Re But, but, but...
I though insects are color blind, or is that bulls, : ' >.....Thanks for question.......Dale
Re: Tuesday filler
Re: Re But, but, but...
I don't know about being color blind, but several of the sources I found while playing with this one mentioned that insects have eyes that are sensitive to the wavelengths that are reflected by this and are attracted to it. Whether that represents "color" vision or not I don't have a clue. I can post the text of one of the sources tomorrow if you like. It is an interesting topic. There are some other advantages to the tree making it from what I read. It also tends to protect the DNA in the leaves from the harmful effects of UV radiation from the direct sunlight. Plants are interesting in their adaptations.
Re: Tuesday filler
Spiders too..
are interesting that is.
I recall a Discovery Planet show that illustrated how certain spiders can build webs that "glow" the "color" that nearby flowers do; at a certain wavelength of light anyway. Only select strands of the web were made this way, and under the right light exposure by scientists you could see them as a funnel towards the center of the web, drawing the insects right on target.
None of this has anything to do with the chemical you're after, but were you looking for "carotenoids"?
Dan.
Re: Tuesday filler
No, see Dale's post
I am on a different computer right now than I did the post from. I will post the full answer and some more info tomorrow whe I am back on that one. Want to be sure that I spell it right ;-)
Re: Tuesday filler
Hi Dan,
I was just messing with ya...I think many things in nature has 'senses' we don't know about yet, much less understand.......Dale
Re: Tuesday filler
I know;-)
If you don't pick on me, who will ? ;-) At any rate, here is a bit of info that I found while looking at this subject. There is a bunch more if anyone has the urge to look. Kind of interesting.
ANTHOCYANIN
By Jack Sullivan
1. Introduction
The red coloration found in bromeliads, cranberrries, carnivorous plants, etc., is caused by plant pigments known as anthocyanins. Because of the interest created in pigment-free forms of certain carnivorous plants, Barry Meyers-Rice (UC-Davis), the editor of The Carnivorous Plant Newsletter, asked me to put together a brief summary of the science of these pigments. While somewhat technical, it's a fascinating topic, especially in the areas of evolution and biology. If you're interested in learning more about this topic, read on!
(This is a modified draft of the paper submitted to Barry for publication in the September 1998 issue of his Newsletter.)
2. Biology
Anthocyanins are members of a class of nearly universal, water-soluble, terrestrial plant pigments that can be classified chemically as both flavonoid and phenolic. They are found in most land plants, with the exception of the cacti and the group containing the beet. They contribute colors to flowers and other plant parts ranging from shades of red through crimson and blue to purple, including yellow and colorless. (Every color but green has been recorded).
Anthocyanins apparently play a major role in two very different plant processes: for one, attracting insects for the purpose of pollination. Advantage is made of the fact that the pigments absorb strongly in the UV (ultraviolet), visually attracting insects but with light wavelengths that are invisible to humans. These pigments play a major role in plant pollination - and in predation in carnivorous plants, attracting insects into the trap apparatus. (Anthocyanins play a very versatile role in pollination, especially in the Bromeliaceae. Certain bromeliads turn a vivid red just before and during pollination but soon revert to the original green color characteristic of the photosynthesis pigment, chlorophyll. Anthocyanins are not a biochemical dead end but rather a dynamic signalling device that can be switched on when needed by the plant to assist in pollination. They are then degraded by plant enzymes when no longer needed to attract pollinators to flowers.)
In their second major role, anthocyanin-related pigments serve as a UV screen and are produced in response to exposure of the plant to UV radiation, protecting the plant's DNA from damage by sunlight. (UV causes the paired strands of genetic material in the DNA double helix to become cross-linked, preventing cell division and other vital cellular processes like protein production).
And in a third, and no less significant role, anthocyanins serve as anti-feedents, their disagreeable taste serving to deter predatory animals.
In a related defense mechanism, anthocyanin production can be induced by ionizing radiation, which can damage DNA as readily as UV can. Chemical messengers apparently signal the damage to DNA and induce anthocyanin production in these plants.
The biosynthesis of this class of pigment is accomplished by a series of enzymes that are bound to cell membranes and that help convert two central biochemical building blocks derived from photosynthesis (acetic acid and the amino acid phenylalanine) found in the cell's cytoplasm through a series of discrete chemical steps into the final pigments, which are then excreted on the other side of the membrane into vacuoles in the epidermal cell layer. Significant genetic change in the DNA coding for the production of these enzymes results in loss of pigment production.
Anthocyanin pigments can be produced by growing plant cells in tissue culture. Plants having no pigmentation themselves in cultivation were subsequently demonstrated to produce anthocyanin in tissue culture.
Environmental factors affecting anthocyanin production included light (intensity and wavelength, with blue and UV being most effective), temperature, water and carbohydrate levels, and the concentrations of the elements nitrogen, phosphorous and boron in the growth medium. Anthocyanin production can be induced by light, blue being the most effective color. Low light levels also induce the formation of different flavonoid pigments, which is another interesting adaptive response on the part of plants. (Tillandsias, for example, develop a bright red coloration due to induced anthocyanin production if grown in strong light. For some additional observations on possible alternate roles for anthocyanin in Tillandsia, see noted bromeliad expert David Benzing's personal observations as quoted in Paul T. Isley III's excellent book Tillandsia .)
3. Evolution
Anthocyanin-type pigments are found only in terrestrial plants. They are not found in animals, marine plants or in microorganisms. It is theorized that anthocyanin production is an evolutionary response to plants first venturing onto the stark primordial landscape under intense UV radiation. (Significant screening of the earth's surface from the effects of UV radiation didn't occur until after the advent of terrestrial plants. Oxygen in large amounts first had to be generated by the photosynthesis of land plants before the UV-screening ozone layer was formed).
The evolution of insect vision to respond to the unique wavelengths of light presented by flowering plants is an interesting scenario, as is the evolution of these plants to take advantage of the insect's attraction to the sight of anthocyanins. Obviously, the plants came first and developed anthocyanins as a defense mechanism long before the first insect evolved. Flowering plants subsequently found in anthocyanin a handy way to attract pollinators. Carnivorous plants took advantage of the pollination attraction mechanism to serve as an effective visual lure for their prey.
4. Chemistry
Anthocyanin pigments are assembled from two different streams of chemical raw materials in the cell: both starting from the C2 unit acetate (or acetic acid) derived from photosynthesis, one stream involves the shikimic acid pathway to produce the amino acid phenylalanine. The other stream (the acetic acid pathway) produces 3 molecules of malonyl-Coenzyme A, a C3 unit. These streams meet and are coupled together by the enzyme chalcone synthase (CHS), which forms an intermediate chalcone via a polyketide folding mechanism that is commonly found in plants. The chalcone is subsequently isomerized by the enzyme chalcone isomerase (CHI) to the prototype pigment naringenin, which is subsequently oxidized by enzymes like flavonoid hydroxylase and coupled to sugar molecules by enzymes like UDP-O-glucosyl transferase to yield the final anthocyanins. More than five enzymes are thus required to synthesize these pigments, each working in concert. Any even minor disruption in any of the mechanism of these enzymes by either genetic or environmental factors would halt anthocyanin production.
Anthocyanin production was used as a visual marker in early studies of chemotaxonomy, which studies the relationships of organisms based on their biochemical constituents. It gave support to the one gene-one enzyme theory that is a central tenet in the field of molecular biology.
BIBLIOGRAPHY
1. Secondary Metabolism , by J. Mann. 2nd edition, pp. 275-285. Oxford Univ. Press, 1987. ISBN 0-19-855529-6
2. Secondary Plant Products , ed. E.A. Bell and B.V. Charwood. Encyclopedia of Plant Physiology, New Series, vol. 8, pp. 340-349. Springer-Verlag, 1980. ISBN 0-387-09461-X
3. Natural Product Chemistry , by Kurt B.G. Torssell, pp. 138-145. John Wiley & Sons, 1983. ISBN 0-471-10378-0 (paperbk).
4. Plant Cell and Tissue Culture , by J. Reinert and M. M. Yeoman. pp. 48-50 (Experiment 13: Callus Formaton and Anthocyanin Production in Cultures of Haplopaapus gracilis.) Springer Verlag, 1982. ISBN 3-540-11316-9
5. Tillandsia , by Paul T. Isley III, p. 92. Botanical Press, 1987. ISBN 0-9617675-0-2.
