Monday, Lovely Rita the metered rain
In still air a falling raindrop is what shape?
Re: Monday, Lovely Rita the metered rain
Re: wag
Like a thick pancake???
sharon in topanga
Another WAG
Tear drop shaped?
Like your title for this question.
Didn't we have this same sort of question during the thread about shot towers? The reason they work is the same.
FNelson
Answer
I should have mentioned and conditioned from how high the water dropped as well as the size of the drop. First of all the tear drop shape is incorrect. The hamburger/pancake shape is correct to a point and the surface tensioned spherical drop is also only partially correct. Size does matter. The larger the water drop the more suseptible it is to alteration. Remember I stated in still air not a vacuum. When dropped from a height the air pressure on the bottom of the drop causes it to flatten (fat pancake) and ultimately it will form into a sort of ring with a nipple like projection. This projection will eventually become too thin and divide into two drops that will, through surface tension be of a general spherical shape but more like jello vibrating all over. Smaller drops tend to drop with less distortion than large drops.
