Tuesday filler
If I wanted to get a big catch of fish, there is a type of tree that I might look for. What is the tree and why? (Of course, I would need to be careful that I did not end up in jail;-))
Tuesday filler
From little acorns....
...a mighty oak grows. Tannic acid...a mighty effective fish poison and around these parts frowned upon by the Rangers. Might that be what you ae after?
Tommy
Different tree.
This one is known for this use;-)
Re: Different tree.
Don't let the Cat out of the bag Dan. Go smoke a big cigar and take a nap.
;-) anyone else know?
Re: Different tree.
I was thinking it was a big gunny-sack of walnuts with the husk repeadedly slamed against concrete. I have no first-hand knowledge of the though.
I don't think that oak would do it. If I were going to try another, it would be Herculese- Club. Also known as toothache-tree or tingle-tongue. Our ancestors used it to numb their last hurting tooth by mushing up a couple of leaves and holding it against the painful spot with their tongue, which would also be numbed.
There is a line of them in a fence-row along a path where I ride my bike. All 6 of them died all at once about 2 years ago. There are a few others about five miles upstream that appear to be following suite. This is not a good sign I don't think. I have wondered if researchers have studied this tree as of late.
Might work, but......
I was thinking of another one. Try "fish poison" as a search ;-)
Re: Tuesday filler
Good evening all, around here when "they" treat a lake they use Rottenone sp? Don't know what tree it comes from, if it comes from a tree.
now I have to look
glc
Re: Tuesday filler
From your comments so far, this probably isn't what you're looking for, but there is a tree called "Catalpa Bignonioides" which annually hosts catapillars which make terrific bait . . . hence one of it's common names, the "Fish Bait Tree".
That's the one I was thinking of too.
Around here those worms get a lot of use. But the tree and worms are usually misnamed around here because of the Catawba river near by.
Basil
The answer *LINK*
This link will give the answer ;-)
The answer
Ok...but...but....
I see what you are after. However my buddy who fishes professionally for the local State Surveys for research tells me the acorn poisoning does occur and is a trick that some guys use to kill fish. I saw walnuts posted too and I am not sure about them. At any rate, it's illegal in these parts. FYI
Tommy
Re: Ok...but...but....
There are actually quite a few items that could be used for this. This ust happened to be the one I was looking for;-) It is probably ilegal in most places. Just thought that it was an interesting "second use" for dogwood.
Sure can't spell today ;-)
