Geeks Part III
Geeks Part III
Geeks Part III
What numeric encoding system is used in most abaci?
Bonus: What mass produced electronic computer used this numeric encoding system?
Re: Geeks Part III
Re: Geeks Part III
If you are considering Chinese abaci with two levels there are two bases used, 5 and 2. IBM computers used base 2, base 5 computers are a mystery to me..
Re: Geeks Part III
There is a name for it.
You are correct. Chinese & Japanese abaci use a hybrid base-2/base-5 encoding system. But there is a name for such a syetem.
Most modern computers use purely base-2 or 'binary' encoding. However, other encoding systems have been used.
At least one commercially produced computer used a hybrid base-2/base-5 encoding system.
Re: Geeks Part III
BCD?
Re: Geeks Part III
Not it.
The decimal digits on an abacus are segregated as in BCD (Binary Coded Decimal), but the encoding is not pure binary.
Re: Geeks Part III
Don't Know the Name for the Code
I've used binary, octal, BCD, and EBCDIC.
My guess as to the manufacturer is either Univac or RCA. I don't think IBM did (or if they did it was well before 1965 when I started working with computers). Of course, Sperry is another possibility.
BobH
Re: Geeks Part III
Set the Way-Back machine for 1953
In 1953, IBM decided that the world was ready for an 'affordable' computer. This machine sold for less than 1/2 million dollars and could fit into a simgle room.
Re: Geeks Part III
OK. Are we Talkin' the 704?
Still don't know what character representation system it used (to include both numbers, alphabet, special characters, control characters, et al. that's what EBCDIC, BCD, and other systems do).
BobH
Re: Geeks Part III
Before the 704
The encoding was very similar to a chinese abacus. Each decimal digit was represented by 7 bits. 2 of the bits had a value of 5 and the remaining 5 had a value of 1. Valid encodings consisted of exactly one bit from each set.
Decimal digits were represented as follows:
0 = 10-10000
1 = 10-01000
2 = 10-00100
3 = 10-00010
4 = 10-00001
5 = 01-10000
6 = 01-01000
7 = 01-00100
8 = 01-00010
9 = 01-00001
Apparantly, Univac used a variant of this encoding on a couple of early models as well.
Re: Geeks Part III
Answer *LINK*
The numeric encoding scheme used on a chinese style abacus is called "bi-quinary" since it combines binary (base 2) and quinary (base 5) representations.
One early computer that used this system was the IBM 650.
IBM 650
