Ragged cut after hitting gravel on the driveway
Caught some loose gravel while edging the farm driveway yesterday and now the mower is tearing the grass instead of cutting it cleanly. I tilted the deck and the cutting edge is completely chipped and dented. I need to order some lawn mowers blades online tonight to fix this. Is it worth trying to file down the chips with a hand grinder, or are they totally ruined once the metal is that chewed up?
Re: Ragged cut after hitting gravel on the driveway
Jim DeLaney, Austintown, Ohio
I grind mine when they're chipped.  They still hold a good edge.  A new set of blades for my Kubota cost about $80, so grinding them is worthwhile.
What Jim said, but be sure to remove an equal amount of metal on both ends for balance. They make a little cone to set the blade on to check balance as well.
Remove the blades.  Grind on bench grinder to get a good edge.  Loop a string through the bolt hole and pick up the blade.  If the blade hangs level,  it's balanced and good to go.  If it hangs tilted, grind a bit more off the "low" end and recheck until it stays level.
If you don't balance the blades, you'll get accelerated wear on your belts and spindle bearings.  You can also sharpen using an angle grinder but clamp the blade to a bench so it doesn't move when you grind.
UPD: Appreciate the advice. I tried to grind out the chips like Jim suggested, but the gravel damage was just too deep. Dale, I was also worried about taking an unequal amount of metal off and ruining the balance, especially since I don't own one of those balancing cones. Just for peace of mind, I went ahead and bought some new lawn mower blades instead. I'll get them bolted on this weekend so I don't risk vibrating the deck to pieces.
A piece of string works just fine, unless, of course, you're dedicated to throwing money at simple problems.
Ruining a mower blade by hitting gravel  does not 'compute'.  You're cutting grass, not slicing paper thin onions and making sashimi.
I have a 16d nail driven into the end of my bench out in the barn that I hang a blade (thru the bolt hole) on to check the balance.
I'm also with Mark about gravel "ruining" a blade.  I normally have a nick or two left in a blade after sharpening that didn't get completely ground out.  I also am not trying to have a manicured lawn (I live on an ag property), so you may care more than I do about appearance of the cut grass.
