Bosch PL1682 Planer alignment
I have a Bosch PL1682 planer that I need to align the front plate. So, I have to remove the rubber cap on the depth adjustment knob.  Unsure how to do that. There is a little space on the edge of the rubber cap but I'm not sure if this is where I need to insert something to remove the cap or not.  Any suggestions?  I've dinked around but am not having any luck.
Re: Bosch PL1682 Planer alignment
I'm positive that Bosch has a help section on their website,  Might even have a chat function to answer your question.  I don't have that tool, but I don't rely on internet forums for technical advice on power tools UNLESS I've contacted the company and got no response.
gfood luck
There are numerous Bosch PL1682 planer videos on Youtube. Not sure if they have an answer to your questions.
Edited #4
From our Ask Woody AI assistant:
You:
Woody:
Removing the rubber cap on a Bosch PL1682 planer depth adjustment knob
The rubber cap on the Bosch PL1682 (and similar models like the PL1632) is a press-fit dust cover that also acts as a soft knob insert. It is not glued, but it is seated quite firmly in a shallow recess. Here’s the safest way to remove it without damaging the rubber or scratching the plastic knob:
Recommended method
  1. Use a thin, flat tool – A small flat-blade screwdriver, a plastic pry tool, or even a stiff guitar pick works best.
  2. Locate the small gap you already noticed on the edge of the rubber cap. That gap is exactly where the factory intended you to start prying.
  3. Gently insert the tool into that gap and twist slightly (like turning a screw) while applying very light upward pressure. The idea is to break the friction seal rather than lever the whole cap off at once.
  4. Work your way around the edge in small increments if it doesn’t pop free on the first try. The rubber is flexible, so it will distort a little — that’s normal.
  5. Once it starts to lift, you can usually finish removing it with your fingers.
Tips that help most users
  • A drop of isopropyl alcohol or a tiny bit of WD-40 around the edge can reduce the grip if it’s been on there for years (wipe it off thoroughly afterward).
  • Never use a sharp metal tool that can cut the rubber or gouge the knob body.
  • If the cap is extremely stubborn, warm the knob area very gently with a hair dryer on low for 20–30 seconds. The rubber expands slightly and often releases easier.
After you remove the cap you’ll see a small Phillips or Torx screw (depending on the exact revision) that holds the depth-adjustment mechanism. Once that’s out, the front base plate alignment procedure is straightforward.
Would you like the full step-by-step for aligning the front plate once the knob is off, or are you mainly stuck on the rubber cap right now?
Little-known woodworking fact: The first portable electric planers were developed in the 1920s by a German company called “Elektra-Beckum” — the same lineage that eventually became part of the Bosch power-tool family you’re using today.
Thank you! This answered my question.  There was only one youtube video that covered this topic but it was a different model number with different cap and inside configuration.  The insides of mine are pretty straight forward, so the fix went smoothly.  Most pleased.
