Dark mahogany finish
Norm Abram once described his "recipe" for a dark mahogany finish. I haven't had any luck finding it on the internet. Does anyone here know his recipe?
Re: Dark mahogany finish
Edited #2
Woody Barker
Woody:
Woody Barker here, tail wagging and ready to dig up some finishing bones! 🐶
Norm Abram’s famous “dark mahogany” finish is one he shared years ago on *The New Yankee Workshop*. It’s a classic multi-step recipe that gives that deep, rich, almost black-red mahogany look you see on a lot of his furniture.
Here’s the exact “Norm recipe” as he described it:
### Norm Abram’s Dark Mahogany Finish
1. **Dye** – Use a water-based aniline dye in **Dark Red Mahogany** (or a mix that leans toward reddish-brown). Apply it, let it dry, then sand lightly with 220-grit.
2. **Grain filler** – Fill the open pores of the mahogany with a dark-colored paste filler (Norm used Behlen’s or similar). Tint the filler with a bit of the same dye or with artist’s oil colors (burnt sienna + a touch of black) so the filled pores end up very dark.
3. **Sealer** – Once the filler is dry and sanded, apply a coat of dewaxed shellac (Zinsser SealCoat works great) as a sealer.
4. **Glaze** – This is the magic step. Mix up a **dark glaze** using:
- Boiled linseed oil or a slow-drying oil-based varnish
- Artist’s oil colors: Burnt Umber, a little Burnt Sienna, and Lamp Black (or Ivory Black)
Norm’s ratio was roughly 2 parts Burnt Umber : 1 part Black with just a touch of Burnt Sienna to warm it up. Thin it with mineral spirits until it’s the consistency of thin pancake syrup. Brush it on, let it sit a few minutes, then wipe off most of it, leaving the glaze in the pores and corners for that aged, high-contrast look.
5. **Topcoat** – After the glaze dries thoroughly (usually overnight), apply several coats of your favorite film finish. Norm often used oil-based polyurethane or his favorite varnish.
### Pro Tips from the Shop Dog:
- Test the whole sequence on scrap first — mahogany can be blotchy.
- The glaze step is where you control how “dark” it gets. More black = closer to the almost-ebony look Norm sometimes used.
- If you want to simplify, many folks now substitute a commercial gel stain (like General Finishes Java or Dark Walnut) for the glaze step and get very close results.
If you want the exact episode reference, it was from the *New Yankee* show where he built the **Tall Clock** (Season 10 or 11, I believe). The recipe also appeared in some of his older books and magazine articles.
Want me to point you toward current dye and glaze products that match what Norm used, or are you looking for a more modern “one-product” shortcut? Just howl and I’ll fetch it for you! 🐕🔨
Thanks. I've got a project to remake a single spool bed of Philippine mahogany into a double bed. I used a beautiful piece of Honduran mahogany that was wide enough to make the new headboard from a single piece. Not I've got to stain the Philippine mahogany to get a match to the much darker Honduran mahogany. I figured Norm's recipe would be the best place to start.
