Have a question? Ask Woody!
Hot woodworking topics
Table of content
Table of content
One of the best ways to help WC become popular again is to answer questions people are currently asking the search engines. Here's a current list of the Top 100:
🔧 Tool & Equipment Questions
  1. What woodworking tools should a beginner buy?
  2. How to choose a good table saw for home shop?
  3. How to align a band saw blade?
  4. How to remove blade drift on a band saw?
  5. How to tune and flatten a hand plane?
  6. What’s the difference between a jointer and a planer?
  7. How to sharpen a chisel correctly?
  8. What grit sandpaper should I use for final finish?
  9. How to maintain and clean a router?
  10. How to square a table saw fence?
  11. What is a “throat plate” and which one should I use?
  12. Is it worth buying a CNC router for a small shop?
  13. How to safely change blades on table saw / miter saw?
  14. How to reduce vibration on power tools?
  15. What is a dovetail jig and how do I use one?
  16. How to make jigs (crosscut sled, taper jig, box joint jig)?
  17. How to build a dust collection / fume extraction system?
  18. What kind of clamps are best for glue-ups?
  19. How to choose the correct router bit for edge profiling?
  20. How to safely use a router table?
  21. How to square up long boards in small shop with limited space?
  22. What safety gear do I absolutely need (respirator, hearing, eye)?
  23. How to mount / stabilize a workbench?
  24. How to set up shop lighting for precision work?
  25. How to sharpen and set plane blades properly?
🧰 Joinery & Woodworking Techniques
  1. How to cut dovetail joints by hand?
  2. How to make mortise & tenon joints?
  3. How to do box joints / finger joints?
  4. How to cut dados and rabbets accurately?
  5. Best method for tongue and groove joints?
  6. How to cut a through tenon vs a blind tenon?
  7. How to cut half-lap joints properly?
  8. How to do floating tenons / domino joints?
  9. How to avoid tear-out when planing / routing across grain?
  10. How to scribe curves or arcs into wood?
  11. How to make circle or ellipse jigs for routing?
  12. How to bend wood (steam bending, laminating) safely?
  13. How to do segmented turning or segmented wood bowls?
  14. How to resaw thick boards into thinner boards?
  15. How to flatten wide boards by hand?
  16. How to taper legs or plinths?
  17. How to inlay wood / do decorative inlays?
  18. How to cut curved / freeform shapes with scroll saw / band saw?
  19. How to align mortises on multiple pieces precisely?
  20. How to mitigate wood movement (expansion/contraction) in joinery?
  21. How to deal with twist, cup, and warp in boards?
  22. How to counteract wood twist when designing a project?
  23. How to veneer wood or apply veneer over curves?
🪵 Wood & Material Questions
  1. How to identify wood species (appearance, grain, hardness)?
  2. How to choose hardwood vs softwood for furniture?
  3. Which woods are good for outdoor use?
  4. What woods are food-safe for cutting boards?
  5. How to read lumber grades (FAS, Select, #2 common)?
  6. What moisture content should wood be before gluing?
  7. How to properly acclimate wood to shop humidity?
  8. What is kiln drying vs air drying?
  9. How to reduce checking / cracking in slabs?
  10. How to fill knots or voids (epoxy, resin, filler)?
  11. How to glue up wide panels without warping?
  12. How to choose stable wood for guitar / instrument making?
  13. How to veneer or plywood vs solid wood decisions?
  14. How to stabilize soft or punky wood?
  15. How to deal with spalting, burl, or figure wood?
  16. How to select wood for turning (bowls, spindles)?
  17. How to cut lumber from logs (milling, chainsaw, bandsaw mill)?
🎨 Finishing, Staining & Sealing
  1. How to apply stain evenly without blotching?
  2. What is the best finish for walnut / cherry / maple?
  3. Oil vs polyurethane — which is better and when?
  4. How to do a wipe-on finish?
  5. How many coats of polyurethane should I apply?
  6. How to sand between finish coats?
  7. How to buff and polish a clear finish?
  8. How to use shellac, lacquer, or varnish?
  9. What is tung oil / Danish oil / linseed oil, pros & cons?
  10. How to repair finish scratches or dents?
  11. How to achieve a “matte” vs “semi-gloss” finish?
  12. How to finish a cutting board (food-safe)?
  13. How to apply finish to end grain?
  14. How to apply finish to live edge slabs?
  15. How to avoid dust nibs in finish coats?
  16. How to thin varnish / reduce bubbles?
  17. How to strip old finishes safely?
  18. How to color wood with dyes vs pigment stains?
  19. How to “raise the grain” (water pop) before final finish?
🏠 Projects & Design / Planning
  1. How to design a small side table?
  2. How to build a Shaker style desk?
  3. How to build a dining table with breadboard ends?
  4. How to build a bed frame with mortise/tenon rails?
  5. How to make cabinets / casework?
  6. How to build a wooden toolbox or chest?
  7. How to build a rocking chair or ladder-back chair?
  8. How to build picture frames with mitered corners?
  9. How to build a wall-mounted shelf / floating shelf?
  10. How to build a router table or tool cabinet?
  11. How to plan for wood movement in tabletop design?
  12. How to design hidden fasteners or hardware-free cabinetry?
  13. How to dimension and layout boards for minimal waste?
  14. How to incorporate curves or organic shapes in furniture?
  15. How to laminate thin strips into curved shapes?
  16. How to build jigs / fixtures for repetitive tasks?
🔐 Safety, Shop Practices, & Troubleshooting
  1. How to set up proper dust collection / air filtration?
  2. How to choose a respirator for wood dust?
  3. How to prevent kickback on table saw?
  4. How to manage shop humidity / seasonal changes?
  5. How to identify and fix squeaks or creaks in furniture?
  6. How to diagnose wood movement problems (cupping, twist)?
  7. How to fix glue joint failures?
  8. How to avoid splitting when driving screws?
  9. How to safely store lumber in shop?
  10. Why is my finish white / cloudy (moisture issues)?
  11. How to fix tear-out on edge routing?
  12. How to safely use a plunge router?
  13. How to prevent glue line visibility?
  14. How to manage MDF / plywood vs solid wood movement?
✅ Tips for Using These in Forum / SEO Strategy
  • Turn each question into a forum thread — make the thread title exactly the question (or something very close).
  • Encourage responses with photos, process steps, and additions (those replies help “bulk up” content).
  • Interlink relevant threads (e.g. joinery → finishing → wood choice).
  • Over time, use your analytics / Search Console to filter which topics attract impressions — expand on those.
  • Use long-tail, low competition ones first (e.g. “how to apply finish to live edge slabs”) — easier to rank.
  • Avoid mentioning Taylor Swift or other subjects that have absolutely nothing to do with woodworking. ;)
Re: Hot woodworking topics
Create SEO-friendly forum posts by using these questions as thread titles, then answer each with helpful tips + photos + step-by-step replies to build traffic and rankings over time.
Edited #3
@johny ki,
That was the intention. I’ve tried this approach before, but some felt it was “misleading” since the questions weren’t coming from real users. I could set up a platform specifically for that purpose, but it seems unnecessary to introduce another system with separate registration when the forum already seems capable of supporting it.
