I had some small 1/2x3/8" Aluminum C channel (U channel) to cut - 24 pcs. I have browsed a few online posts and decided to use my "rougher" construction miter saw (60T blade?), not my shop saw with the 80T blade. Need 12" pieces so I set up a stop block, slid the piece into place, and cut. WHAM - flying metal!!! I was wearing safety glasses but no face-shield or other PPE.
I believe what happened is that on the upstroke the cut piece on the right side was trapped between the blade and the stop block (no hold downs were employed in this near-miss/disaster); it lifted and flew off to my right. 2" on the end of the retrieved piece was distorted/mangled (very thin walled C or U channel). Like many MSs, this has the motor on the right side, and I believe that motor help me from getting hit by this flying piece.
Only then did I recall the important tidbit from Rushton on NCWoodworker.net that I HAD READ in my search: "Just make a slow cut and don't lift the blade out of the cut until you've turned off the saw and the blade has stopped." Well, I remembered the slow cut idea but neglected the second part of that.
Rushton said:I regularly cut aluminum t-track with my miter saw and carbide tipped blades. Just make a slow cut and don't lift the blade out of the cut until you've turned off the saw and the blade has stopped. I don't doubt that it's possible to chip a carbide tooth in the process, but I've never had it happen over 20 years of doing this
Likely 'could' have been avoided with use of a proper hold-down; further mishaps were certainly avoided when I just made a mark for length (not critical to have exactly sized pieces) and did not use a clamped stop block for the rest of the cuts.
"Be safe out there"
Henry - Prolific creator of sawdust, and sometimes shavings - with the occasional completed project.
