WE MOVED...
Reviews and opinions of "milk" and "chalk" paints
My daughter likes to refurb old furniture using chalk paint. Although I would not paint over quality wood, most of what she does is either too far gone to restore the finish or it was never much to begin with. Chalk paint, forgiving of a perfect prep, some new hardware, and it often looks better than what you would get new from IKEA.
Any experience with this stuff? Tips, tricks, caveats?
We were also approached by RMP Finishes, who manufactures what they brand as Real Milk Paint made of milk protein (casein), lime, and pigment and comes a powder to be mixed with water. Maybe they'll send us a sample? Will I get high if I drink it?
Re: Reviews and opinions of "milk" and "chalk" paints
Milk paint is easy to use, and generally I like the results.  It is a rustic look finish, dries flat and sometimes a bit bumpy.  You can buff with steel wool for a smoother finish but you might get some wear through at corners and any high points, requiring a recoat.  I think straining the paint is recommended if you want to avoid the bumpy finish.  One thing that is often done is to do several coats of contrasting color and buff aggressively to wear through giving it a very old look.
One thing, once mixed it has no real shelf life.  Maybe a couple days.  In humid places, I don't believe the powder has much shelf life either, a few months once opened.  Where I live, it's pretty dry and unmixed paint lasts well.
You can also go over it with a thinned oil finish like tung or linseed.  This darkens the color and gives it a little sheen.  Its a fun product with which to experiment, because the results can be varied so much with pretty simple techniques.  Its also good in that it doesn't peel as it ages, it's a very stable finish.  I don't believe it holds up well outdoors, it is an interior only finish I think.
Maybe a year ago, shellac.net had it on sale.  I think they were closing it out so that may not still be the case.
No, but the casine might stick your tongue to the roof of your mouth
:o
Edited #4
Never cared for the lack of durability of it, but the colors are often bold and the surface is almost like a prime.
I have, fairly often, used it on junk stuff brought into the house and then sprayed it with just single part target semigloss waterbase clear. it holds up well for that - easier to get bold color and the look under semi gloss clear is nice, if not as rustic or "chalky".
When it's sprayed with clear like that, the durability is increased by...i don't know 50? it's better than any so called high adhesion paints that still get knocked off of corners easily.
WB clear has to be added with care, though - thin sprayed layers and each must dry to avoid hydrating several day old WB paint that will soften allowing everything (paint and all) to come off.
Added later 09 min:
if you're interested in terms of as and advertiser, they are legit. I haven't used their paint, just chalk paint bought on a whim, but same principle with the WB clear.
however, RMP offers a pretty good array of solvents and oils that are good quality, which isn't always the case for hardware store stuff. They are not cheap, but the only thing that's cheap and good is buying bulk oils, etc, from a place like jedwards, and nobody really does that other than....well, me and a few folks who can justify a minimum order amount. And jedwards is like half the cost of anywhere else, so it gets harder to hit the minimum. Who would like five gallons of oil at one time?
In solvents and oils, RMP is kind of on par with ....trying to think of something that's a reasonable comparison ... bobs red mill in grains and flours.
