I am building an outdoor bench out of eastern red cedar. The back is 54 inches wide.
I have made 1/2 inch wide by 1 1/2 inch mortise in the top and bottom pieces. The top and bottom are 4 inch wide by 1 inch thick by 54 inches long. I used the old bench as a templet and made 14 mortises for slats. So do I glue the top and bottom of each slat? Do I leave them float? Do I glue in every other one for support? Or do I just give up woodworking and just take naps all day?
Thanks
Mike
To Glue or Not To Glue, that is the question?
Re: To Glue or Not To Glue, that is the question?
Edited #2
Give up and take naps before the slats make you fail like Tamar.
https://www.youtube.com/watch?v=pzmUJ7Pck6U
#3Glue baby, glue.
#4I would recommend gluing all the slats with a water proof glue.
#5Alrighty looks like Gorilla glue is on my buy list.
Thanks
#6I think gorilla glue, the polyurethane species, it not well suited for outdoor use. I believe Titebond III would be a better choice
#7I agree. Titebond III
#8Seriously? Polyurethane glues, or whatever gorilla is are similar to time tested outdoor construction adhesives. I don't generally use Gorrilla glue, and never use Titebond III, so I am not pushing it, but for specific reasons I used it to rebuilt the rear deck on my trimaran. Generally gluing wood that will just sit outdoors doesn't work very well unless the whole project has engineered encapsulation. Or some really appropriate wood like teak, but even that isn't so great judging by the many benches I have examined in the UK.
#9Glue and pin.
Forget the Go Rilla. It will fail with the greater outdoor wood movement. Especially if your m&t's are not very tight fits.
Glue? Epoxy. Pins? 5/16" hardwood dowels, through-drilled and sanded flush.
