What is the primary advantage of using a skew chisel over a standard chisel when turning wood on a lathe? 3/29/25, 12:03 PM #1 Peter Martin Peter Martin Moderator Offline 913 posts Info Registered: 10/16/05 Location: Virginia USA Website Pick one. Reply to elaborate on your choice. Question 1 What is the primary advantage of using a skew chisel over a standard chisel when turning wood on a lathe? It removes material more quickly (0 [0%]) 0% It creates a cleaner, shearing cut with less tear-out (3 [75%]) 100% It is easier to control for beginners (1 [25%]) 33% It works best on softwoods only (0 [0%]) 0% In total voted: 4 Guest can't vote.
