The following is from https://metalworkforums.com/showthread.php?t=210928
I thought it might make an interesting question for our trivia forum.
Looking for ideas, guidance, thoughts etc. from the brains trust out there.
We are starting to look at ways of weighing our locomotives and rolling stock, static weights only, not dynamic, and need to come up with a plan that is safe, reasonably accurate and, given that we are a volunteer based self-funding railway, reasonably affordable. When I raced superkarts we used 4 bathroom scales - I have a feeling that may not be the optimum solution in this case...
The largest of the locomotives is around 200 tons, the heaviest axle load will be in the order of 20 tons.
People have mentioned load cells and strain gauges, we're trying to work out how these would be rigged on a rail line, at this stage we are open to all ideas - the primary requirement is that the solution must be safe and robust as any solution that risks derailing the locomotive is a no-go.
Ideally the mounting solution would be something that could largely be built in-house using our own machining capabilities in order to save on costs.
