I am getting ready to install the wood counter top on what we are calling a coffee bar. The size of the top is 62 x 26 x 1 1/2 inches glued up maple 62 x 4 x 1 1/2 . The cabinet is made of 3/4 inch maple ply if that matters.
Normally I use caulk to install a counter top. I was about to do the same thing, then figured I better ask. Should I use screws from the bottom with elongated holes? Or caulk?
I will most likely be installing this tomorrow.
Thanks
Mike
Wood Countertop install
Re: Wood Countertop install
Caulk (silicone) will do. Ours have been down for about fifteen years.
Edited #3Jim DeLaney, Austintown, Ohio wrote:Caulk (silicone) will do. Ours have been down for about fifteen years.
Thanks. How is it going?
Added later 55 s:
Mike L wrote:Jim DeLaney, Austintown, Ohio wrote:Caulk (silicone) will do. Ours have been down for about fifteen years.
Doing well. Staying busy.
Starting "Leaf Season" so cleaning up after the 40+ Oak and Maple trees is going to keep me busy for a while. Glad I have the Kubota BX and the DR vac trailer, for sure.
#5I have a BX and a Cyclone Rake for my 10 or so Oaks and another 15 or so other trees. They make the work easier. Have a good one.
#6I would attach a cleat to the wall on the left side and then use silicone on the cleat and also on the cabinet top.
#7@rlipeles. That is the plan. A small fridge will be in that spot. I hope to have it installed this afternoon along with the plumbing. I still have a hole to drill for the faucet, level and square it then install the wall cleats.
Thanks
#8Don't forget a bead of silicone to seal the wall joint. Bead goes on the wood slab so it fills any gap in the rock. A top bead won't do so well damhikt
#9@Mark Mandell
I did apply caulk to the wall also. The backsplash will be tongue and grove to the bottom of the upper cabinets. I will be installing a small piece of trim from the top to the back splash.
Thanks
