Miter saw: Am I crazy?
Source: https://www.reddit.com/r/woodworking/comments/1feu2jj/miter_saw_am_i_crazy/
Been doing some projects recently that call for some very visible miter joints. At first I went to my…miter saw. But the miters sucked - gaps everywhere! And I have spent the time to make sure that my saws are squared, fences are squared, adjusted my detentes, etc. So I moved to my table saw and my cuts are as tight as…well they’re tight. So am I crazy that my miter saw is basically useless for precision miter cuts? If I didn’t own an older home with lots of trim work all over the place I swear I would toss it in a ditch.
Hmmm. I figured a miter saw would be the go-to for cutting all miters, but I guess they are really designed just for rough framing (follow source link for comments)?
Re: Miter saw: Am I crazy?
It all depends on the miter saw.  I have the Boush GCM12SD.  I put it on a mobile stand, did an alignment of all the stops, and made sure the blade was at 90 degrees to the bed.  It cuts miters spot on.  I had a few older miter saws with the two rods so they would cut larger pieces.  They would cut descent miter joints, but I always was fiddling with them to keep it square.  I also had an old miter saw with out any slides or gizmos.  It cut miter spot on also.  Miter Saw
If cutting a lot of molding, then a miter saw without slides might be the right chose, do the adjustments, and forget it.  If doing larger stuff then the Boush is had to beat.  Cry once and move on.
If the saw is bad then precision results aren't likely to be good. Is the blade mounting arbor runout acceptable? It should be very little but I can't be specific.
Is the problem a "non-90 degree" joint or is it little gaps along the cut. If so, is the blade sharp?
Is the workpiece remaining tight to the fence and also does not move along the fence while cutting (even a very little).
I have a non-slider Delta that wasn't very expensive (years ago) and I've been happy with it.
Edited #4
Maurice
It's an old problem with many possible causes. Blunt and or gummed up teeth on the saw blade can cause deflection very easily. Different timbers prefer different rake on the teeth. Some commercial shops use negative rake which tensions the blade in the cut and improves accuracy. Harmonics in the motor and gearbox can cause flutter in the blade especially in harder timbers.
All to often the solution is to reduce your cut rate. Take it easy. A lot of guys are like a bull in a China shop with mitre saws.
Backing block's support the cut better because it stops the piece vibrating as you  cut. Those teeth are like thousands of hammer blows to the timber and deflection leads to imperfections.
Some guys don't even let the saw come up to speed before they cut ! Lol.
But then there are mitre saws that are just plain crap. If you want the ultimate perfection in the cut you can't beat the old guillotines.
Generally speaking if I need perfect mitres I use my home made cross cut  cradle on the panel saw. Not my compound Makita.
I will use a backing strip clamped to the fence for maximum support.
For small delicate mouldings on Harpsichords I make a mitre box and cut them with a Japanese saw.
OR make a mitre shooting board and use a low angle block plane if you want perfect.
So many ways to skin the cat.
Carbide blades are rarely perfectly sharp for more than a few hours after regrinding. They are not as infallible as people think.
I keep one cross cut blade aside just for mitres. It doesn't get used for anything else.
Added later 7 h 59 min 43 s:
Ps. Thin blades are prone to distortion under load. Try a thicker kerf blade.
Dunno. My semi-ancient DeWalt DW716R seems to produce tight miters as long as the blade is clean and sharp. Of course I did do all of the appropriate alignments. Come to think of it it is probably time to check the blade and alignments again since it has been a couple of years now. I wonder if a simple down-up saw like mine is less susceptible to errors than the down-slide-up sort.
Edited #6
John McGaw (Bodger) wrote:
... I wonder if a simple down-up saw like mine is less susceptible to errors than the down-slide-up sort.
Anything that guides/moves is a potential source of error.
Edited #7
Maurice
Excellent points. Accumulative error is just a fact of life. I didn't mitre the beads on my windows and door's. I coped them to get better moisture resistance. But as in all things there are so many extenuating circumstances and options to consider.
Mitres have a nasty habit of opening up in some applications but when properly applied ? Very satisfying.
Added later 03 min 07 s:
Absolutely 💯.  Keeping guides clean and dust free helps but the more complex the set up the more room for error to accumulate.
Anyway, preaching to the choir here.
Not surprising from a noob on reddit.  They are describing the woodworking equivalent of "problem exists between keyboard and chair".  I see this a lot at work too, people thinking that the machine makes precision, when really it's the skill of the machine operator that does it.
The first thing one does cutting miters with a power saw is cut and check.  Just because you set it on 45 doesn't mean it comes out that way.  People seem to forget this, just like forgetting to RTFM.
When size of pieces permit I use a Lion Trimmer. I keep the cutters razor sharp and it does a great job.
