Framing a base for a 3400-lb fish tank
The following is from Reddit. I thought this might be interesting to get opinions on--both to spur some forum activity and because I'm personally interested in this. I'm not a woodworker, but I do occasionally make things like this for the garage where the #1 objective is structural integrity and not aesthetics. And I'm not versed in how to calculate tension and compression loads, and usually second-guess myself on how to do the joinery.
As a novice, my first thoughts are that maybe some cross-braces would be in order, but then after considering it will be skinned in 1/2" plywood, that may not be necessary. And that if any consideration had been given to the floor; i.e., if joists, would they carry a 3200-lb load on that footprint?
So what do you think? Anything you would do differently?
From Reddit:
Will this hold a 300 gallon aquarium on the top, with a 125 gallon sump underneath? Estimated weight is 3400 lbs. The 2x4s are all notched, and sistered together with wood glue and screws (stronger than a 4x4). We’re going to skin it with 1/2 plywood tomorrow for additional strength.
will-this-hold-a-300-gallon-aquarium-on-the-top-with-a-125-v0-km1wizum8odd1.jpg?width=1080&crop=smart&auto=webp&s=f7b9657ce2de3d3417789ee170eb64434f2235fa
will-this-hold-a-300-gallon-aquarium-on-the-top-with-a-125-v0-zwn6setm8odd1.jpg?width=4032&format=pjpg&auto=webp&s=07b3eb53b622a7aebeef22897ba801b985452df2
will-this-hold-a-300-gallon-aquarium-on-the-top-with-a-125-v0-4ki9ketm8odd1.jpg?width=3024&format=pjpg&auto=webp&s=ec66a3d0b301f16a616e4f2b66496fe7922fa335
will-this-hold-a-300-gallon-aquarium-on-the-top-with-a-125-v0-8yqvuftm8odd1.jpg?width=3024&format=pjpg&auto=webp&s=df7f1368ded4f24a2434ad57742560f59b404f51
will-this-hold-a-300-gallon-aquarium-on-the-top-with-a-125-v0-q7gwvktm8odd1.jpg?width=3024&format=pjpg&auto=webp&s=c1d393a749bce02f66ed2100daff288325826955
will-this-hold-a-300-gallon-aquarium-on-the-top-with-a-125-v0-0ayluftm8odd1.jpg?width=4032&format=pjpg&auto=webp&s=e689d44b133678522de04ef703018f86cdf055d1
Re: Framing a base for a 3400-lb fish tank
Douglas fir posts will support 600 psi, which is far stronger than necessary to support that weight. I also agree that it must be skinned with plywood to provide shear strength. And I agree that the bigger question is whether the floor will support that much weight. I'd want to be really sure that it would.....
As with any cabinetry or long piece, I'd include some sort of adjustable leveling hardware.
