Will it work?
Privet wood for knife handles?
Re: Privet wood for knife handles?
#2Have you done a Google search? Ligustrum, none are native to USA, has about 50 species. If they are like any other genus with many species your mileage will be all over the place. Give it a try.....
This is the response from Perplexity AI when asked:
Yes, privet wood can be used for knife handles. Here are a few key points about using privet for knife handles:
Privet is a dense hardwood that is suitable for knife handle material.[1] It has good working properties and takes a nice finish when sanded and oiled.
Some woodworkers recommend privet for tool handles and mallets due to its density and durability.[5] The same properties make it a viable choice for knife handles as well.
Privet has a straight, fine grain which is desirable for knife handle scales.[1] The fine texture allows for a smooth, comfortable grip.
While not as exotic as some woods used for handles, privet is a readily available and affordable option, especially if you have access to privet trees or logs.[5]
The main drawback of privet is that it can be prone to cracking or checking as it dries, so proper drying and sealing of the wood is important to prevent issues with the handle over time.[1] Using a stabilizing finish like tung oil or Danish oil can help prolong the life of a privet knife handle.
So in summary, privet makes a perfectly acceptable, durable, and affordable material for DIY or custom knife handles if you take proper precautions in drying and finishing the wood.[1][5]
Citations:
[1] https://knifewear.com/blogs/articles/why-are-japanese-knife-handles-made-out-of-wood
[2] https://www.wikihow.com/Make-Knife-Handles
[3] https://www.americanbladesmith.org/community/handles-and-guards/how-do-you-seal-your-handles/
[4] https://www.linkedin.com/pulse/why-we-use-g10-knife-handles-all-our-mkc-knives-josh-smith
[5] https://sawmillcreek.org/showthread.php
