Well not really new, but sure act's like it now. It is a left tilt Delta Uni Saw with Bessy fence vintage 2008 or so.
In 2019 I moved from OH to TN. I took the TS apart and had it stored for several months. Fast forward to 2020 and I put it back together again, and just kind of used it when needed. I am getting to make a few cabinets and figured I better get the little things that bugged me worked out.
First one was the the fence would catch on something when sliding towards the blade. I always thought it was the side table was not adjusted to the to the saw top. Today I took it apart and figured out the bolt that holds it to the cast iron was pulling it down. I ground out the hole a bit and now it is flush. The fence still catches a bit but now on the miter slot edge. I think I need a new plastic piece the fence slides on.
Second was just a plain clean out of the inside. I found loose bolts holding a guard in front of the blade. Tightened them up. No more rattle noise. I used a dry spray lube on anything that moves. Cleaned the cabinet all out.
The last trick was adjust the blade for zero and 45 degrees. The 45 degrees is dead on. The zero is off about 3 thousands from bottom to top when fully up.
So onto my questions. Is that 3 thousands an issue at zero with the blade fully up? If so where do I adjust it. The handle goes alway to the stop.
Thanks Mike
Wow a new TS
Re: Wow a new TS
RE: whether .003" is important, you didn't mention the blade height at which you measured this discrepancy. If it is at full height (~3") it will be less important than if it is at 1" height for most situations, but why not adjust it if you can?
To illustrate, I just glued up a table top made of two 20" wide boards. If I had ripped both boards on your saw, and if your measured error was at the 3" height, this would have produced a depression of less than 1/32" at the glue line. If the error was measured at 1", the depression would be more on the order of .06" or about 1/16". That would be unacceptable to me. I jointed the edges with a hand plane and made sure they were perfectly square before gluing, but if you're in the habit of glueline ripping, it would likely be an issue for you at some point.
I've never seen the inside of the left-tilt model, but usually there is a bolt, often with locknut, that you can advance or retract to stop the tilt mechanism at the desired location. This should be evident if you remove the top to make the adjustment. It may not be accessible otherwise.
Hope this helps. Let us know how it works out.
Re: Wow a new TS
#3Thanks
It was with the blade at full height so ~3 inches up. The bottom of the blade had the clearance. I don't think I will worry about it right now. I looked for a bolt and jam nut to adjust. The only one I could find was for the 45 degree mark.
I really don't want to take the top off unless I have to.
Mike
Re: Wow a new TS
Yeah, reattached the top is yet another alignment exercise. I wonder what the fix is?
Re: Wow a new TS
Edited #5
Mike L.: It was with the blade at full height so ~3 inches up. The bottom of the blade had the clearance. I don't think I will worry about it right now. I looked for a bolt and jam nut to adjust. The only one I could find was for the 45 degree mark.
Mike
Maybe loosen the bolts on one end and insert shims? Shouldn't take much - maybe one layer of beer can metal? Otherwise, unless you're making a lot of full depth cuts, I'd leave it alone.
OTOH, was the measurement made with only one blade? Could be a 'blade plate problem.'
Re: Wow a new TS
#6Since your 45*s "dead on" leave the top/cabinet joints alone. The adjustment you need to make is with the tilt trunion's top stop. This is an easy adjustment. You will find a hex bolt head and a stop nut above the top of the trunion gear againt which a small tab make contact. You can see this on the right side of the cabinet as you open the tub-door. All you need is an adjustiable wrench. Back the tilt 10* or so, loosen the hex nut, then adjust the hex bolt in or out until your blade is also dead-nuts at 0*. Finally, re-tighten the nut to lock the bolt in position.
Re: Wow a new TS
Jim DeLaney, Austintown, Ohio wrote:Mike L.: It was with the blade at full height so ~3 inches up. The bottom of the blade had the clearance. I don't think I will worry about it right now. I looked for a bolt and jam nut to adjust. The only one I could find was for the 45 degree mark.
MikeMaybe loosen the bolts on one end and insert shims? Shouldn't take much - maybe one layer of beer can metal? Otherwise, unless you're making a lot of full depth cuts, I'd leave it alone.
Yes, I agree with Jim. A couple shims will fix the situation, but you may have to re-calibrate the 45º stop, too.
And while we're talking about shimming tables, sometimes you may need to "supertune" your tablesaw by shimming either the front or back end of the table to keep the blade from burning on 45º cuts.
Re: Wow a new TS
#8Mark Mandell wrote:Since your 45*s "dead on" leave the top/cabinet joints alone. The adjustment you need to make is with the tilt trunion's top stop. This is an easy adjustment. You will find a hex bolt head and a stop nut above the top of the trunion gear againt which a small tab make contact. You can see this on the right side of the cabinet as you open the tub-door. All you need is an adjustiable wrench. Back the tilt 10* or so, loosen the hex nut, then adjust the hex bolt in or out until your blade is also dead-nuts at 0*. Finally, re-tighten the nut to lock the bolt in position.
BINGO. I just took the side cover off and found the stop. After playing with it a bit I have it set dead on. The 45 degree didn't need another adjustment.
Now everything is all set and ready for me to start my next adventure of making cabinets.
Thanks
Re: Wow a new TS
#9I took the Beismeyer style fence off my saw and set it on the floor beside the saw. When I put it back on one of the faces of the fence would catch on things on the table. (Where wings joined and even the miter slot.) Looked at it carefully and apparently the side had slipped down less than a 1/16". I used a clamp and rubber mallet to move it back up and all is fine. (Now to find the shop gremlin that stepped on it or dropped something on it.)
Re: Wow a new TS
#10Barry Irby wrote:I took the Beismeyer style fence off my saw and set it on the floor beside the saw. When I put it back on one of the faces of the fence would catch on things on the table. (Where wings joined and even the miter slot.) Looked at it carefully and apparently the side had slipped down less than a 1/16". I used a clamp and rubber mallet to move it back up and all is fine. (Now to find the shop gremlin that stepped on it or dropped something on it.)
Thanks I will look at that. I adjusted the side wings and the side table so there is no lip anymore. This took care of most of the catch. I then slid it towards the blade and it caught on the blade side of the miter slot. I just replaced the little pads on the bottom of the handle to give it a bit more lift. It seems to have fixed the catch. I will check the side of the fence to see if they got whacked around during all the moving. No shop gremlins here I sent them all to VA for a vacation(-;
