Japanese knife sheath
I have an old chef's knife that my neighbor wants to gift to her husband. Just needs handle finishing and final sharpening.
I would like to make knife sheath. The issue is I have 1/8 inch x 6 inch Honduras mahogany veneer. The wood is warped,twisted and I want to use. What are the options for straightening ? I have plenty of clamps just don't know how to proceed. Thanks
Re: Japanese knife sheath
Edited #2
I have been working quite a bit with AI and like comparing its answers to human answers to the same question. I posed your question to ChatGPT3.5, and following is its response. It writes well, I'll give it that. LOL. Is it accurate? IDK. Feedback, anyone?
ChatGPT wrote:
Straightening warped and twisted wood veneer can be a bit challenging, but it's possible with some patience and the right approach. Here are some steps you can follow to try to straighten your 1/8 inch x 6 inch Honduras mahogany veneer:
  1. Assess the Severity: Determine the extent of the warping and twisting. If it's minor, you may be able to correct it. If it's severe, it might be challenging to completely eliminate the distortion.
  2. Moistening: One common method to straighten veneer is to introduce moisture to the wood. You can lightly dampen a clean cloth and lay it over the veneer. Allow it to sit for a while (several hours or even overnight) to let the moisture penetrate the wood. This can make the wood more pliable.
  3. Use Weight: Place weights evenly distributed over the warped areas. Heavy books, bricks, or anything with some weight can help to press the veneer down and straighten it. Ensure the weight is distributed evenly to avoid creating new distortions.
  4. Clamping: If the warping is severe, clamping may be necessary. Use your clamps to gently press the veneer back into shape. Be careful not to over-tighten the clamps, as this can cause damage or create new problems. Place blocks of wood or scraps between the clamps and the veneer to distribute the pressure evenly.
  5. Heat: In some cases, applying gentle heat can help with the straightening process. You can use an electric iron on a low setting, but be sure to place a cloth or parchment paper between the iron and the veneer to prevent direct contact.
  6. Repeat if Necessary: Depending on the severity of the warping, you may need to repeat the moistening, weight, and clamping process several times until the veneer is straightened to your satisfaction.
  7. Allow to Dry: After straightening the veneer, allow it to air dry completely. This might take a day or more, depending on the thickness and moisture content of the wood.
  8. Apply a Finish: Once the veneer is straightened and dry, you can apply a finish to protect the wood and enhance its appearance.
Keep in mind that veneer is thin and delicate, so be gentle during the straightening process to avoid damaging it further. Also, the success of this method depends on the severity of the warping and twisting, so results may vary. If the veneer remains distorted despite your efforts, you might need to consider replacing it or seeking professional assistance from a woodworker or cabinet maker.
https://chat.openai.com
Added later 03 min 02 s:
Following is the answer by Claude, a version of AI trained on a different dataset.
Claude wrote:
Here are some tips for straightening warped 1/8" thick mahogany veneer using clamps:
  • Lightly dampen the wood on the concave side to relax the fibers before clamping. This allows it to flex easier.
  • On a flat surface, position it with the convex side facing down and concave side up.
  • Use cauls (straight pieces of wood) above and below to evenly distribute clamping pressure.
  • Place small, closely spaced bar clamps across the width of the veneer. Tighten gradually, working from the center outward.
  • Add heavier parallel clamps along the length, using the bar clamps as cauls. Tighten to press out remaining warp.
  • Check with a straightedge and adjust clamp positions to target high areas until flat.
  • Once flat, put weight on top and allow to fully dry before removing clamps. This helps minimize back bowing.
  • Consider laminating the veneer to a stable substrate like MDF or plywood to maintain flatness after.
Go slowly when tightening to avoid cracking thin veneer. Correct moisture content and heavy clamp pressure should allow the mahogany to compress back flat.
https://claude.ai/chats
Both AI answers have kernels of accuracy and usefulness, but also some misdirection. For instance, Claude seems to be confused between flattening veneer and flattening a board that's developed cross grain concavity, i.e., cupping. I get the impression, correctly I assume, that these programs have been trawling human written sources, some good and some poor to generate plausible appearing solutions. As a consequence the answers generated seem to combine all of the source material, good and not so good, and spit out answers that display evidence of no real experience of working with veneer.
Here' my veneer flattening guide: Flattening Veneer PDF  I'm definitely not AI, so therefore the attachment is all my own work, just in case you were wondering, ha, ha. Slainte.
I am concerned that a wood sheath will retain moisture and cause the blade to rust. My preference for the sheath is leather.
I am curious as to how you plan to construct this sheath, Mike. Typically, a wooden sheath is made by routing mating pockets in two bookmatched pieces of wood and then gluing them together. If you're using wood that is only 1/8" thick, this isn't possible. You would have to create the pocket by gluing a third, possibly thicker, piece between your two outside layers of mahogany. If this is your plan, I see no need to flatten or straighten the mahogany, as the laminated bundle will be as straight and flat as the cauls you use to clamp the layers together.
A couple other things: 1/8"-thick mahogany veneer may not be strong enough to resist cracking along the grain if it is dropped or handled roughly. I suppose it's worth a try, but you may want to consider using something thicker. Also, wooden sheaths often have a thin layer of leather glued into the knife pocket to grip the blade lightly and isolate it from the wood.
admin wrote:
@Sgian Dubh, is this the same Richard Jones?
https://www.woodcentral.com/forkbb/user/1082/Richard%20Jones
T
he first two posts at your link are mine, i.e., the chest of drawers and the double twisted dovetail articles. I don't recognise the other Richard Jones who seems to have made or contributed to all the other posts or topics at that link.
On a side note, since I first started posting at this forum sometime in or around 1999 I've always ended them with the greeting Slainte, just in case you're trying to separate me from the other Richard Jones. Slainte.
Edited #9
@Sgian Dubh, thanks, the two topics have been changed to show you as the author.
Consider the purpose of the sheath. Is it strictly utility or is the sheath also a cosmetic addition. Does the material damage the steel? The Japanese have a long tradition of combining utility and good durability. They use specific woods for sheaths. Keep in mind they are historically limited by species availability, but the choices reflect protection.
Here is a link to sheaths for Japanese cutlery.... https://www.bitemybun.com/best-saya-japanese-wood-knife-sheath/
