Something Old and Something New
When I graduated to my Stubby 1000 from the JET 12-36 I naturally got into large bowl work.  Of course, I soon found out that one runs out of space to display such stuff in fairly short order.
I turned this 22" salad bowl in Ambrosia maple
While the bowl was turned to about 1/4" the rim was left fat
The finished piece has sat around for years, and while people were impressed with the size and color, I was bothered by its big flat rim as it made the bowl look very heavy.  I recently redid the vacuum system for my lathe and decided to violate the "never return" rule.  I put the bowl back on the lathe, cranked up the vac to 28", and returned the rim so that the outside edge is still sharp but now the rim is rolled into the inside surface.
What a huge difference in the feel of the bowl!  The whole thing was lightened up visually and the rim has a lovely "feel" and works with my personal bowl design preference.  SWMBO has approved the "new" bowl for use and display.
On the new front, I found this jar hiding in one of my few remaining Red Maple log sections.
10x5 with my usual lacquer/wax finish.
I'm gonna be disappointed when my Red Maple stash is gone.  Have to look for more.
Comment welcome
Re: Something Old and Something New
Looks like you broke the rule to........
....good advantage Mark, working thru the old finish is no picnic!
On large bowls, I like a tapered rim in the reverse of what you did. It leaves a sharper corner for the thumb to get a better purchase and lifting the bowl one handed feels more secure with the sharper edge on the inside.
Design Language
I think of a bowl as consisting of 3 parts: the outside curve, the inside shape, and the rim.  In my view, the outside curve is, essentially architectural; it works, with or without a foot ring, to support the other elements.  The inside shape is the working potential; it determines what it will hold.  The rim, then, works to hold those two elements together.  I've done bowls with essentially no rim, bringing inside and outside to a knife edge or a very narrow flat.  I've done some with a very wide rim that included various kinds of augmentation so that the rim and its texture etc. really become the reason for the design.
As you mention the edge grip, I find that I really like the "thumb feel" of the rolled inside edge.  But that's pure preference.
Cheers
Lyle Jamieson
I like that rim treatment Mark, It is inviting.
Good Comment
It does invite being touched.
Thanks
So True, Jamie
at least as far as the finish goes.  20 years ago I settled on Waterlox , both red and blue.  Haven't found anything to replace them for bowls so it was easy to get things to match.
