Re: suggestion for a food safe finish that will/may not darken the wood as much as Walnut oil
John -- All finishes sold in the USA are 'food safe' once fully cured. (Someone here will post a link to the report from the federal government that reaches that conclusion.) So, if I needed a clear finish that didn't darken the wood as much as walnut oil, I'd probably go with Deft Clear Wood Finish (which is a brushing lacquer). It is a film finish that is easy to apply and is fairly durable. You might prefer one of the water-based lacquers. They alter the color of the wood even less than Deft. However, Deft 'warms' the appearance of the wood slightly. Water-based lacquers tend to make the wood look cold. Deft slightly yellows the wood, while the water-based lacquers give the wood a slight blue cast. I prefer the look of Deft and avoid using water-based finishes for that reason.
Another option is pure tung oil. (Lots of finishes have tung oil in their names. Some of those might even have tung oil as one of their ingredients. You want the real thing.) Like walnut oil, tung oil is a hardening oil. I don't use it because it is harder to find and costs more than walnut oil.
Note: While all finishes are food safe once fully cured, that doesn't prevent some people from being reluctant to use an item that is finished with anything but a finish that could be eaten straight out of the can or bottle. Arguing with them seldom does any good.
HTH
