Burial urn - Ponderosa pine
Joe Fleming
All, This is a burial urn that is 9" D and about 11" tall with the lid. It is Ponderosa pine. It is sealed with shellac and then finished with tung oil. The inside is sealed with tinted epoxy. The lid is a tight friction fit that is VERY difficult to remove once pressed in place.
This was a commission that I discussed a few months back in the chat. The customer's sister was a forest ranger at Sequoia National Park and she wanted the urn to be from a native species to that park. Henry Doolittle acquired the wood for me.
Re: Burial urn - Ponderosa pine
Very nice! That super tight stopper bothers me though. A very tight fit along with seasonal wood movement might just crack the urn.
Very nice, Joe.
Since you turned end-grain, I wouldn't be too concerned about seasonal movement as both the jar and the cap will move together.
With the dimensions you list, the piece is more than twice the usual size for 1-person cremains.  Wondering why so big?
Joe Fleming
Re: Burial urn - Replies
Dick, Mark,
Thanks for the comments.  You both ask excellent questions.  This is my first urn.  I know the 1 cubic inch per pound of person rule.  I was told that I should be good for 200 cubic inches.  My vessel is probably about 325 cubic inches give or take.  Why so big?
  • Short make window.  Would not have time to redo it.
  • Thick walls.  Not sure what the norm is, but I opted for 0.25" to 0.375" thickness.
  • Seeing many Mike Mahoney hollow vessels all around volleyball to basketball size, I got that size in my head.
  • My dad's urn was a rectangular box that was considerably larger.  I got that size in my head.
  • Shopping on line for commercial urns gave cubic inches but not always physical dimensions.
  • The customer gave me maximum size constraints, so I went to those.
Needless to say - I learned a lot on this project.
The press fit lid was not really my first choice, but I did not want to experiment in a short time window.  I wanted a threaded joint, but need more practice.  I did buy the bronze insert from Niles Bottle Stoppers, but they have 1.5"D and 2.5"D.  I really needed 2"D.  I do know that Ponderosa pine will not move too much, so I'm not too worried about cracking.    Also, the urn is being buried, so I was less concerned about it sitting on a table for years and cracking.  Not the best answer, but its what I went with.
Joe
Volume
Pie x R[squared) x Height
Taking you 9x11 for 1/2" walls by 9" interior height 4x4x3.14x9 gives you 452 cubic inches of volume.  That's big enough for a dual (husband/wife) urn.
Sealed with a cork.  Not buried, however.  Will be held until children pass and then re-cremated with them and scattered.
Re: Volume
As a Buddhist, I'm looking into a Tibetan sky burial. What these articles don't mention is that the rogyapas (body-breakers) are usually quite inebriated. Perhaps a custom-turned wooden ax handle would be a thoughtful remembrance? I suspect there will be lots of volunteers to make one if I change the menus again.
Re: Volume?
May be oddly appropriate, but your link goes into "thin air"
Re: Volume?
Hmmm, looking at the source code, there seems to be nothing wrong with the link. What happens when you click on it?
<a href="https://www.dailymail.co.uk/news/article-2376190/Chopped-fed-vultures-glimpse-closely-guarded-tradition-Tibetan-sky-funeral.html" target="_blank">Tibetan sky burial</a>
Re: Volume?
Link worked for me, interesting human remains disposal
Joe Fleming
Re: Volume
The top two inches are lid and neck, so mine's more ball shaped.  Used the volume of a sphere = 4/3 x pi x radius cubed.  8.5"D (4.25"R)
There is a lot to be said for a premeasured bag of rice or sand squished into the approximate form so you have an eyeball on the needed size.
BTW - Mark, nice piece.
Works for me
Retry
Worked 2nd time
Re: Volume
Re: Volume
I try to shape a plastic bag filled with the appropriate amount of rice into the shape of a truncated cone.
One of the hardest things to do is estimate how much rice is needed for a given volume.  For instance 20 cubic inches for a 20 pound animal is how much rice?  Here is a web address that does the figuring for you to answer that question.
http://www.metric-conversions.org/volume/cubic-inches-to-us-ounces-table.htm.
The table on this site reads that I need 11.1 ounces of rice in a regular liquid measuring cup for the volume I will need for the animal's cremains. So I put that much rice in a plastic bag and shape it into the general shape of a truncated cone and then position it on the piece of wood I wish to use to see if it will accommodate the volume I am intending to put inside it.
For those of you who are more mathematically inclined and wish to more accurately determine the volume of the hollow form I suggest you think of the interior shape as a truncated cone i.e. a cone with the pointed end cut off .  By determining the diameter/radii at the top and bottom and height of the hollow area inside the urn there is a formula that can be used to accurately calculate the volume.
Volume= ⅓ π (r12 + r1r2 + r22) H
Or more simply just go to this link and plug in the height, radius of the major diameter, radius of the minor diameter and hit calculate to let their computer do the work for you.
http://keisan.casio.com/has10/SpecExec.cgi?id=system/2006/1223372110
Once this volume is known the trick with the rice can be used to visualize the internal volume needed for the cremains.
Re: Volume
They said there wouldn't be any math...
