V Belt Question
V Belt Question
V Belt Question
So I am doing my motor conversion with a treadmill motor .My existing belt,L475 48x750, is 30+ years old. Do these get hard over time? Should I consider a different type of belt. Maybe the notched type V belt?
Re: V Belt Question
Re: V Belt Question
When I put a treadmill motor own my old delta I used a serpentine belt, it matched the pulley on the treadmill. I made a wooden pulley out of locust for the headstock
Re: V Belt Question
Re: V Belt Question
If it is a standard 4L V- Belt you could use power twist link belt.� They are a little more expensive; but, you have the advantage that if you have a lathe that has the pulley between the headstock bearing and the rear bearing. Will not need to dis-assemble your lathe to install it.� Not sure if this type of belt is rated to run forward and reverse.
Re: V Belt Question
George Balock
Re: V Belt Question
If you have the opportunity, I'd replace it.  The additives that they use to keep the bely pliable dissipate over use and time.  An alternative to making a pulley to match would be to try McMaster Carr to see if they have a pulley that is close to the one you want.  The problem with a wooden pulley is number one wear and two becoming out of shape with changes in humidity.
