Veritas - Innovation in Tools
Claro Walnut Pepper Mill
Jim in Burlington Ont.
Hi,
It's been awhile since I posted any of my turning, thought I'd share this recent one.
It is turned from Claro Walnut (love this wood), stands about 12" tall, using a Crush Grind mechanism.
I like the simple line and shape, a present for my step daughter Emma.
Take care, Jim
Re: Claro Walnut Pepper Mill
Nice job. Good looking wood and finish.
Hi, Jim
Long shallow curves can be hard to do and prevent flat sections.
Nice piece, well done
Joe Fleming
Denatured alcohol source?
Hey Mark, can you give a link or pointer to your source.  I hate the methanol stuff and cannot even buy it here in California.  I'm looking for a good source.
I like this style too, Jim...
Well done.
Re: Denatured alcohol source
Company: FulFill Manufacturing, Inc, 940 Williams St., Sam Leandro, CA 94577,  Brad Schuler
Buy through ebay for a better freight rate.
Joe Fleming
Seems to be out of business.  Website is not found and phone number is disconnected.
Bummer
Sent Brad an email.  Hasn't bounced but no reply yet.
If you do a search on ebay, you'll find several others selling 200pf ethanol.  Need to make sure it's methanol free.
Thank You!
Take care, Jim
Thanks Mark,
Indeed, the sweeping line was one I had always liked and the mill got a bit slimmer working through my cuts, in the end the dimensions looked right to my eye.
Take care, Jim
Re: I like this style too, Jim...
Thanks Gary,
Take care, Jim
About buying ethanol and using
If a mix of water and ethanol is boiled the condensed vapor will be 95% ethanol and 5% water.  This concentration will prevail until all the ethanol has been vaporized from the water- ethanol mix.  This mix is called "190 proof".  (95% x 2 for some historical reason).  Product for sale that is "190 proof" is likely a product of fermentation followed by distillation from the aqueous fermentation of some sugar source( or here in TN moonshiners  :)   )
This product can be dehydrated by further distillation to yield nearly pure ethanol, 200 proof, plus a minor amount of impurities.  Alternatively ethanol can be made from ethane from natural gas wells to yield an exceptionally pure ethanol that is 99+% ethanol.
Any of these products can be rendered not easily drinkable by adding back chemicals that are hard to remove and either toxic or repulsive.  This product has the added name "denatured" added to the ethanol. There are dozens of products labeled "denatured" that vary by what is added.  The SDS will reveal what has been added.  Then guess if the additive will affect the shellac.
If shellac is dissolved in 95% ethanol and applied to wood, the volatilizing ethanol will carry away the water with the vapor that will be 95/5 ethanol/water.  Hence, it would not seem important whether one prepares shellac in 95 or 100% ethanol.  I have never noticed a difference. (rapid evaporation can condense water on the wood, but that is a different story. )
There can be advantages to formulating finish in a solvent mix, such as a mix of alcohols.  Upon application the lower boiling solvent flashes off quickly which increases the viscosity of what remains. Runs are minimized.  The higher boiling solvent hangs around to keep the applied film low enough viscosity to level.  Products like lacquer will have several solvents in the formulation to minimize runs and promote leveling.   I take advantage of a mix of ethanol/methanol or ethanol/isopropanol depending on whether I am finishing when it is hot or cool.  Zinsser shellac has a high boiling ketone that aids leveling, but results in slow drying.
Always be mindful that methanol and ethanol are sufficiently volatile that flammability needs to be considered.
thanks for the good info, Bill
