Finally turned something
I've been a bit overwhelmed lately with farm/house things, pandemic burnout, some European travel, new dirt-moving equipment, and a few medical things to take care of. And incubating/hatching/raising several hundred guineas, turkeys, and chickens - what a lot of work!
I think I've turned just twice since March of 2020! - some "magic" wands to prepare for a demo last year and a simple garden tool handle to replace one I lost in the weeds long ago.
But I had scheduled a demo for earlier this month (on turning metals on the wood lathe with woodturning tools) so a few weeks before I HAD to get moving or be greatly embarrassed! I had planned to turn a lidded box to illustrate one use for small brass turnings so I grabbed an old 4x4 chunk of Albizia and made this:
Since I was out of practice I was a little nervous and expected to destroy at least one box (I hadn't turned a lidded box for years) but a miracle occurred and it came out ok. Once I had the sharp tools in hand and the wood spinning everything fell into place, just like I'd been turning all along.
If you haven't turned brass (or aluminum) on the wood lathe, it might be worth a try. I use standard woodturning tools, mostly Thompson (gouges, parting tools, NRS, etc) sharpened as for wood. I've turned steel too with a scraper I ground from Thompson steel, but it's not nearly as much fun...
BTW, this box was one case where I first carefully designed the piece on paper since getting the curve right on the bottom let me align the feet at the position I wanted and perpendicular to the surface with no unpleasant surprises!
The lid has my easy-to-use taper fit instead of the common suction fit with woodturner's bragging rights.
And if anyone is interested, this is my tool handle replacement. When I found the weeding tool the handle had disintegrated in the dirt. The stainless steel part and ferrule were fine. This simple handle from Osage Orange should last longer!
