Lipstick
Lipstick
Lipstick
On a pig?
Had this section of Black Birch that didn't show any cracks and appeared dry so I figured to give it a go.  Looks can deceive.
Pared down to about 11x11 so decided to do a globish kind of form with pebble grain finish.   Turned out to be fairly wet on the inside (that's why it started out crack-free :D ) and just wanted to move and crack as I moved in.
So
Not a globe for sure.  Wanted to keep the knot graphic in the collar section so slewed it off center on the pith points but in reducing the diameter it kept shifting toward the circumference so the collar is somewhat large for the piece.   Hollowing produced a whole lot of vibration, even though the tools were sharp.  Had me checking and re-checking both the Kobra's connections and the Stubby's sliding bed to make sure they weren't getting loose from the vibration.
Came out looking a bit like a squished grape
The annular ring grain was something of a disappointment so pulled out the needle scaler to give the surface some interest and the walnut stain helps hide a multitude of strange goings-on in that tree.
Wondering if I should stick some kind of finial on top.
Comment welcome
Re: Lipstick
Lyle Jamieson
Re: Lipstick
I never turn anything with the pith in it.� Chances of survival is slim without cracking.� �
Re: Lipstick
Mark...
You will think me mad -- as in crazy! -- perhaps I am, but here is what I immediately saw in my mind when I saw your form.
Perhaps it's because I'm about to create an "aubergine" dye for an NE vessel I'm working on.
Nevertheless, in doing the research, I learned that the "aubergine" color is purple+brown.
So I recommend that you airbrush on some purple dye and create a finial that looks like the above stems.
You could even do a little carving on the collar if you were so inclined.
It's kind of like the form we know as a "seed pod", only bigger!  ...GG
Re: Lipstick
Clint Searl
Crazy as is
Re: Lipstick
Re: Mark...
Hmmm,
Eggplant, eh?  Perhaps some tomato sauce and Parm could help? :D :D
Don't have an air brush, but do have a mini hvlp gun that will do a tinted clear at 4psi.
Hmmmmm
Re: Lipstick
Re: Lipstick
Nicely done, Mark! I like it. I think the tinting and pebble texture give the piece the look of pottery and allow the collar to really shine. I hear your criticisms. In this case, I think you're being overly critical of your work. Yes, the shape is a little squat and the collar may be a little too large. But, the overall effect is pleasing. I wouldn't be ashamed to have the piece in my living room or in the lobby of my office.
Re: Lipstick
Re: Mark...
I've had very good luck with TransTint.  It appears to be one of the more light-fast dyes.
The Dr. Ph. Martin Bombay India inks are excellent too.  They are pigment based, and hence archival, and come in a wide assortment of transparent colors -- you can buy several different color wheels for a reasonable price.
I bought the three TransTint primaries (red, blue, yellow) and black, and I can make any color.  (I make different browns for highlighting burl figure but keeping a basic wood color.)  The containers don't work well for measuring or neatness, so I transfer a small amount of each dye into its own small "needle" bottle, and that way I can get a precise drip and drip count with no mess.  Record your recipes for future use. ALWAYS wear nitrile gloves!  No way to keep it off your fingers, so cover them (and your clothes!).  I wear a turning smock under a shop apron when working with them.
Re: Lipstick
Tinting
I was, in fact, considering tinting a layer of dewaxed shellac to play with some color.  I'm not a painter, preferring to let the wood speak for itself.  You suggestion is due consideration.  I have a shelf of TT dyes that I mostly use in epoxy.
Time to Play
[an Eggplant??]
Re: Lipstick
when in doubt...
...make moussaka.  :-)
Re: Lipstick
Learned
that eggplant, while used as a vegetable most everywhere, is actually botanically classed as a "fruit".
Now that Costco is selling ground lamb, moussaka is on the "to-make" list :D
Re: Lipstick
Re: Lipstick
Globish? � As in a glob (no "ish" suffix needed)? � Or, "Globish" an alleged subset of the English language:� https://en.wikipedia.org/wiki/Globish_(Nerrière)
Eggplant, which is neither a fruit or a vegetable, but just an inedible seed pod would be a good description.
Re: Lipstick
Well Well Well
Look who the cat dragged in!
You a fugitive from the AAW forum or just cruisin'?
:D
Re: Lipstick
And
Don't you answer your emails, Bll?
