Prayer wheel - fun turning project
This is a prayer wheel I made for friends of mine. They are both musicians and the song on the outside is one John wrote for their wedding many years ago. (Laser engraver had some issues, so it wobbles a little, but still looks pretty good.)
Base is dyed Curly Maple with Kingwood holders. The wheel is Curly Maple with Brazilian Cherry lid and base. Handle is, I think, also Brazilian Cherry. The bead is Bloodwood with a 1/2" steel bearing epoxied inside as the box was heavier than intended and this provided (more than) sufficient weight to get it spinning. Bronze bearings in the box base and handle top. Quarter inch steel rod runs from the lid to the handle, epoxied into the lid. Used a hangman's knot to tie the nylon cord to the box and bead. (No intended commentary on marriage.)
As I understand it, the idea is to write a prayer and put it in the box. Every rotation of the wheel signifies one recitation of the prayer.
In the base.
On side, in front of base.
Disassembled.
Re: Prayer wheel - fun turning project
Nice job, Craig. Very thoughtful and well executed.
That is quite beautiful! Just lovely and precision work.
Thanks Mike.
There is that one form of box that you make (yes, I know you didn't originate it, but you have mastered it) would make a good box for a prayer wheel. The bead could be a miniature of the box, similar to what I did with this one, and the handle could be an elongated form of the same shape. Think it would make a pretty classy looking prayer wheel.
Thinking of the ones like pages 70 and 72 in Chris Stott's Turned Boxes book, the shape of the alternate on page 70 and the main pic on page 72.
