A Texturing Tip
A Texturing Tip
A Texturing Tip
In the process of doing a jar in black birch (about as hard a hickory!) and decided to put pebble grain on most of the exterior.  Given the needle scaler's effect, I was a bit sloppy in shearing/sanding out all the latitudinal surface marks from cutting and sanding figuring the scaler's impacts would wipe them out.
Wrong move, Mark.
All those lines persisted into the pebble grain, so I had to re-sand the piece down to 320 to get even texture in the pebbled surface.
If you go the surfacing route on your turnings, don't skimp on getting a truly clean surface before you start your "augmentation".
Re: A Texturing Tip
yep, LOL, we hear it time and time again -- FORM BEFORE TEXTURE!! ;-)
Re: A Texturing Tip
Sanding after texturing
I feel your pain, Mark, but I can think of instances where the texturing (or other process) produces some sort of fuzz or micro-splintering at the surface that needs to be sanded back. Maybe your needle scaler merely compresses the grain, unlike a burr in a Foredom tool.
Re: A Texturing Tip
Re: A Texturing Tip
I follow the same philosophy before adding any burn lines with wire. Sand to completion, burn and then sand lightly with the highest grit to clean up.
Re: A Texturing Tip
Re: Sanding after texturing
Exactly, Boss.  All the "needles" have been rounded so all I have is a surface composed of little dents.  That said, before applying finish the piece will be gently re-sanded with 1,000 grit paper to take off any crowns between the dents.
I've also been tempted to sand back to a smooth surface and then wet the piece to bring out the round pebbles.  Maybe on the next one.  The birch I'm using is pretty plain-jane.
