How 'Bout This
Wondering if anyone here uses this cut. It’s done with a bowl gouge, ground with an Ellsworth profile that’s given a slight hone inside the flute. The tool is held level and at a very low angle incident to the surface with the bevel actually rubbing the surface like this:
Then the gouge rotated very slightly until it just starts to cut. Then the cut is made as a push. Gotta be careful, however, not to get greedy or things will not go well in a hurry.
The shavings come off like what Ellsworth used to call “angle hair:”
This shows where the edge is cutting.
I’m using this to carefully refine an outside curve with minimal sanding needed.
