Second attempt. Posting image of teapot.
OK, 2nd try. Don't know what happened to the first.
  Here is a picture of that "teapot" I have been working on. Think there are a couple things I would have done differently. Some of the proportions, maybe a smaller/slimmer base. Some of the proportions are just my bad photography. The central angular peak in the lid handle is a shadow. The lid actually transitions smoothly to the rim detail. Probably should have skipped the rise after the initial bead.
  Main sphere/body is about 4.25" in diameter. It is Masur Birch, dyed initially teal but the finish first applied added yellow, resulting in a more green appearance.
  Base and lid are Mopane (Mopani?), a very dense wood that will sink in water. Used for making clarinets, as it has very good tonal properties. The root burls are used for fish tank decorations.
  Lid handle is African Blackwood, a rosewood, and also used to make clarinets but getting scarce.
  The handle and spout are Yellowheart. Making them, and more so, attaching them was a nightmare. This was the 4th pair. One was made too large, one had grain orientation wrong and I forget what happened to the other. Spout and handle are from an eccentric doughnut like what Neil Scobie described in the February 2014 issue of American Woodturner.
- Craig Daymon
Re: Second attempt. Posting image of teapot.
Second time's the charm
Glad you got this posted, Craig. If you ever have trouble posting again, please leave us a message on the Feedback forum detailing whatever it was that didn't work, and we'll try to either fix the problem or guide you to the answer.
What an ambitious project! Clearly you had fun with this piece, although the handle and spout were challenging. I so rarely do constructions with my turnings that it is always a treat to see what others can do. This piece is certainly a testament to your skill and patience. Thanks for posting it. Nice work.
Re: Second time's the charm
Thanks Ellis.
The problem may have been that I sent out the image to a few non-WoodCentral folk. (I know, crazy that there are such folk.) So to save time when posting here, I selected all in the email I had sent and pasted it in. I was surprised that the image and all the text pasted right in. Maybe it was something to do with pasting in an image instead of using the message tool to do so?
I do wish I could have preserved the original teal color I had before applying a coat of finish that added amber and moved it toward green. That really looked good. Not to mention that I had a peanut butter jar with what was left of the teal dye mix for the life of me I can't find it. Lesson learned and another reason to organize better.
Bingo, you are correct. When you pasted from your email, the editor found and displayed the images from their location on your computer, but when the message was posted to the web, it cannot access files located on your computer--it can only locate files hosted somewhere on the web.
Never thought of that, so thanks for explaining what happened as a heads up to others.
