A55 Smoothing Plane
sharpening grit test
I finally had time to do a grit size sharpening test. I picked a piece of wood that easily shows any error in cutting or sanding lines. I used African Ebony. I sharpened my Thompson 1/2" V bowl gouge using the 40/40 method to 40 degree nose angle using mu 350 grit CBN wheel. I made a pass across the ebony. then I ground the same gouge to the same angle using a 36 grit gray wheel. Made a short pass on the end of the ebony. I could not tell the difference. The course grit is the right end and the fine grit is just past the groove. I did it 3 times ( it hurt to grind away that much steel but really it was only probably .010") The test came out the same all 3 times. If I have time tomorrow I might try another wood but I've found the ebony to be a really tell all to how well my tools are cutting. Anyway. I guess the important part of sharpening is to get repeatable angles, make sure you sharpen all the way to the tip ( which can be harder with the finer grits) and sharpen frequently. What grit you use is apparently unimportant. OK now that I said that the finer grits do have some advantages. One is you remove less steel each time you sharpen. An edge ground with a finer grit will last longer. I have seen this in my own experiments but it's well documented in The English magazine Woodturning and there was also an article in American Woodturner the showed this.
Re: sharpening grit test
interesting
Bill Blasic
Re: interesting
John for me using the Vector Grind Fixture I have found that the 180 grit CBN wheel gives me the best combination of sharpness and how long that sharpness lasts. With your knowledge of sharpening I find no surprise that you would get the same result regardless of grit. I'm sure you have a very light touch that takes off very little steel. I would like to know if you found the combination of sharpness and how long that sharpness lasts with those same grits and if your results reflected those of mine. I know folks who went to higher CBN wheel grits and although they got sharper that edge didn't last as long.
I like the finer grits for a spindle gouge because they leave a smoother edge.  A cut in dense, fine grained wood can be smoother, sometimes needed no sanding (if I'm steady enough.)
John   I did the test again yesterday.  I turned some beads as well as  new straight cuts.  The bead on the left and flat area on the left are from the 350 grit grind.  The bead on the right and flat area on the right are from the 36 grit grind.  The 2 flat areas on the right and left of the bead were turned with a skew ground to 1200 grit and stropped.   There isn't any difference.  The photo doesn't do it justice.  I tried several different lighting scenarios to try and show it better.
