Delamination of roughed bowl blank
Mike Stafford
Mike Stafford
A friend of mine who is relatively new to turning came to me with a problem. And after seeing it and discovering what he did I don't know what happened and I don't know what the can do to fix the problem.
He had rough turned an 11 inch cherry bowl to about a uniform 3/4" thick everywhere except in the area of the spigot on the bottom. Then he dried it in the microwave. After each drying cycle he weighed the bowl so he would know when it was dry. He figures that when the bowl no longer loses weight it is as dry as he is going to get it.
He dried it in the microwave 61 times until it stopped losing weight. He then let it sit for a couple of days to acclimate. After acclimating the bowl measures about 11 1/4" end grain to end grain and 11" face grain to face grain.
When he went to mount it back on the lathe some of the face grain on one side of the bowl was delaminating. I am sorry I don't have a picture but perhaps you can visualize a nicely shaped 5" tall by 11" diameter bowl. On the outside curve on just one of the faces which has exposed face grain there is a section of the face grain which is delaminating along the grain line from about 1/3 of the way from the bottom to the rim. At the bottom the wood along this grain line feathers to almost nothing but at the top where it intersects the rim it more than 1/4" thick.
I hope that makes sense. I have no idea if the bowl can be salvaged. I am fearful that the entire big section of face grain will pop off if he has any trouble with his tool control.
I don't have any experience with microwave drying of green wood but 61 cycles cannot be good for the wood. Any of you use a microwave to dry your roughed bowl blanks? How do you go about it?
Any suggestions on what he might be able to do to salvage the bowl/
He lives way, way out in the country and he doesn't have any form of internet access so he can't post a picture.
Re: Delamination of roughed bowl blank
John Jordan
Sounds like ring shake, which is common in cherry. Maybe had nothing to do with the drying. I would recommend he not turn it at least until he has more experience.
John
Mike Stafford
Mike Stafford
John, I considered ring shake but this is only one layer and only on one side of the bowl. It just doesn't look like any ring shake I have seen.
I don't approve of his drying method but he is convinced it does not harm the wood. Personally I think he is "case hardening" the wood.
I found this when I was looking for an answer for the condition his wood was exhibiting...
"Case hardening describes lumber or timber that has been dried too rapidly. Wood initially dries from the shell (surface), shrinking the shell and putting the core under compression. When this shell is at a low moisture content it will 'set' and resist shrinkage. The core of the wood is still at a higher moisture content. This core will then begin to dry and shrink. However, any shrinkage is resisted by the already 'set' shell. This leads to reversed stresses; compression stresses on the shell and tension stresses in the core. This results in unrelieved stress called case hardening. Case-hardened [wood] may warp considerably and dangerously when the stress is released by sawing."
Ditto what John Said. I have seen it in Bradford Pear and some Cherry that I got. You can't see it from the outside but once you start turning it appears. Very dangerous. I had 4 bradford pear go down in a storm and every piece I cut from the trunk portion of the tree had it. When I was lucky I could see it from outside but other times didn't find it until I was half way through the bowl.
Wind shakes
jorge
Wind shakes is another name for it. In cherry I've seen it many times sometimes a whole ring about 2 inches around the pith
separates from shaking in high winds. Seen this also in ash and red oak from the wood around here
Also happens in lightning strike trees
Dick Coers
A lightning strike can cause the same issue. I think it’s a problem with the lignin being changed from the heat.
Mike,
It sure would be nice to see and touch it. Is the delaminated part still tightly bound everywhere except for the very edges or will it come loose if you pull on it?
The rapid drying defects I'm familiar with don't separate along the rings but small areas collapse inside a thick piece, for example a type of severe internal checking called honeycombing. I've seen it in kiln-dried Oak and Maple. From what I've read about case hardening it causes severe stresses in the dried wood (under tension on the outside and under compression inside) that can, for example, pinch a saw blade when cutting, but not cause separation or internal checking.
Without seeing it, when I read your description my first thought was like the other Johns, ring shake. I've seen it in walnut, chinese chestnut, cherry, and even once in mesquite. The delamination can be severe - all the way around the ring in multiple layers, just a single tiny portion, or anything in between. It is not unusual for it to be on one side of the log and not the other.
Ring shake is in the tree when cut but may be tight and not evident until dry.
In some cases I've had chunks of wood fall apart while chainsawing. Others don't show up until the wood is cut into turning blanks and have dried some. It is not unusual for the wood appear to be OK at first with the rings tight then separate during drying. Just recently I sliced a piece off the end grain of mostly dry blank - it had a check from the side that went about an inch radially following a ray before it turned and followed a ring maybe 20 degrees or so. I threw the whole blank away.
One question about the microwaving - is this the first time he's done this and were past dryings successful? How long was a typical cycle? I've only dried small pieces with a microwave, 1"x1" spindle blanks and it did take a lot of cycles. I'd run the oven for just 20 seconds or so until the outside felt warm, not hot. Let cool then weigh. Repeat. Seems like it only took 15-20 cycles for that size of wood.
Does he still have scraps from cutting out the bowl blank. I'd want to get those and cut and examine thin transverse slices by bending. I test every blank this way that I process from green wood.
Im with John on this,
Keith Newton
If it followed the annual ring, that was already there. If it was from drying unevenly, those are perpendicular to the rings, or radially from the heart.
As for lightning, yes it can cause something similar, but there will always be a little crease where the scar tissue meets in the middle as it comes in from both sides capturing a little bit of bark.
Depending on the severity, some may heal over within the same year, but some may be 5-6” wide and take several years. In those you can see where the annual ring curves in and terminates against the year before, maybe several times befor it meets the new scar tissue from the other side.
Ric Taylor
Ric Taylor
I used to microwave wood but it has been a long time since I tried it. I only did small pieces, never a roughed bowl.
When something is microwaved, it is cooked/heated from the inside out, the center is what gets hot. What I did was a process that was mentioned on many forums at the time. I used the defrost cycle and turned it on for 20 seconds, then let it cool for at least 15 minutes, usually more. This required many cycles, and with other things going on it would usually take a couple of days. I had success but in the end I decided that it was too much hassle and I quit doing it.
My WAG is that your friend may have used a power setting that was too high, and didn't allow enough time between cycles for proper cooling.
Mike Stafford
Mike Stafford
He microwaves on high for 20 seconds. He says it is too hot to handle at the end of the cycle. I am still convinced his drying process damaged this wood.
I have seen wind shake, wood damaged by felling and a number of structural problems caused by the wind. We live in a hurricane zone so wind damaged trees is a common problem.
This looks different as it only affects one set of annular rings.
No answer....enough time wasted on this as I don't believe he will change. He is always in a hurry to turn....
Even leave  hoe out in the rain?
Or a shovel, or any other wood handled tool? A few wet dry cycles and the wood delaminates at the growth rings. I suspect the dry/wet cycles accomplished the same thing. Some time during this course of events the outside was bone dry and the middle still wet. The outside was trying its best to shrink but the inside would not let it. The stress simply fractured the outside along the weak rays of the wood. Happens all too often drying oak (weak rays that easily fracture under stress) if the schedule is too aggressive. 60 microwave cycles was certainly aggressive.
Personally, I have seen a lot of cherry sawed and never seen shake in cherry. The heartwood of cherry is usually fractured but this is not the same phenomena as the ring shake common in hickory or hemolck, for example.
I don' t know anything about turning bowls. But end grain looses water around 10X faster than flat grain. I would think a bowl would dry sufficient in days with good circulation. The challenge would be keeping these things from drying too fast.
Ric Taylor
Ric Taylor
There it is, microwaving on high power is part of the problem. He should be using the defrost cycle or low power. And no mention of how long he waited for cooling between cycles.
Example
Let me preface by saying I know nothing about drying bowls. But I have dried a lot of lumber for our former business. Round stuff dries different from flat stuff, and bowls may fall in the category of round stuff. Shown is a shovel handle that got wet too many times, and dried too fast in the sun. Note is it not split radially, like a board would split if dried too fast. Rather, it has split along the growth ring boundaries, perhaps like the bowl in question. Wet handles always split this way, not radially.
BTW, "wind shake" is more likely to be caused by infection or other factor that affects the adhesion between growth rings. See Richard Jones, "Cut and Dried" page 215, for example.
